17-07-2017 #61
17-07-2017 #62
So, if I'm interpreting that correctly, you have a double ball-nut set-up like my machine?
I could do something like this although it would mean making a new retaining flange. I have to say that apart from grinding spindles, I'm not a fan of spring-loaded solutions. I'm also not convinced that backlash of 0.01 is much of an issue. My conventional mill has about 0.25 backlash and it's only a problem with heavy climb-milling or slot milling and then it can be overcome by reducing the feed rate and the depth of cut. Mind you the table and slide alone must way 200kg - mass helps, as do well adjusted gibs.
I meant to have asked what the rest of you mill consists of Robin - got any pics?
17-07-2017 #63
17-07-2017 #64
17-07-2017 #65
There's a build log from many years ago, I will try and link it...
http://www.mycncuk.com/threads/651-W...ht=Warco+Major
I fitted zero backlash double nuts, big disappointment, so I sprung them and it was like magic.
The springs mean that I have no backlash up to 1/4 ton but if I ever pass that loading presumably everything will go horribly wrong.
I do get some sideways slop in the quill if I forget to pack it out with thick, icky grease. Open to suggestions.
17-07-2017 #66
I might give the belleville washer thing a go. The Fehlmann's vernier adjustment is clever, but I think a grub screw lock would be better as it would allow finer adjustment. Quality manufacturers have a nice trick of fitting a pressed-in brass plug in the adjustment nut before threading it so that you have a formed locking piece that doesn't damage the thread and needs little pressure to lock.
Regarding your quill slop, there isn't really a satisfactory solution. The fit of a cylinder into a bore is something that requires a degree of precision and careful fitting at the point of manufacture - surface finish is critical. Any fool with a cylindrical grinder and enough patience can make a cylinder to size and parallel to a micron or two, but getting the bore honed for a perfect transition fit is another issue altogether. Most of the Chinese machines fall at this point, although I have to say that Myford's VMC (Taiwanese) had a pretty decent fitting quill - though not to Swiss, German or the best US and GB standards (has to be said though that most of the machine tools produced in the UK were not of a particularly outstanding fit in this respect).
You could split the casting and put a clamp in place, but this is a pretty crappy solution as you're going to get lots of point contact at the clamp position (the bore will be an oval) and you'll still have the original clearance further up. Alternatively you could get the quill hard-chromed and ground to a nominal size slightly larger than the clearance, but then you have the difficult honing issue mentioned above. Not worth doing either of these, better to start again with a higher-grade machine and transfer your clever CNC additions to it.
If you've got space there's been some fantastic 1980s CNC machines on eBay recently including a couple of Deckel FP3/4s for about £1500! Fab things with superb ball-screws and servos (probably old brush types though).
17-07-2017 #67
18-07-2017 #68
Most kind. This is the magic of CNC, it frees you from straight lines and you enter a wonder land of flowing curves. If I only had 2 more axes I could do blobs.
27-02-2020 #69
I have some parts from an older machine looks like PICOMAX100 that was being disposed of by a machinery dealer .
It used sevo motors and timing belts to drive the ball screws .
when I arrived the controls had been chucked in a skip , the sevos removed and the intention was to strip the rest to get rid of the 3000 K that was in the way .
I still have the sevos , the SF 32 spindle , some SF30 tooling , the roller slides , massive leadscrews ( maybe 30mm ) with ball nuts and bearings .
So true sevos when others used steppers ! - well as you say , it IS Swiss.
27-02-2020 #70
What a shame it was scrapped - I would have considered buying it.
I've only just started working on the old Fehlmann again after a couple of years of inactivity. My machine is a pain as it was originally only two axis. The Picomax 100 was a three axis machine that used the quill rack and pinion driven from a worm and wheel belt driven from a servo as the Z axis. It sounds like a terrible idea when one thinks about the average drilling machine rack and pinion, but being Swiss there's virually no backlash. As I mentioned earlier in this thread, the extremely clever engineer I bought the machine from had made a worm and wheel drive (the aluminium housing seen on the right hand side) to drive the pinion. However, I have found that because he used a fully throated worm wheel it has been almost impossible to remove the backlash.
I will probably end up using a ball-screw to move the quill, but I have recently reinstated the machine's original worm and wheel drive (which employs a gashed bronze worm wheel) and have backlash of about 0.01mm - not bad. I shall see how it works in practice once I have mounted the stepper motor to the original 90º cross-helix gear drive to the worm shaft. There is significant backlash in this gear, but it will be unimportant in terms of the ability of the quill to remain in position because of the worm and wheel - the backlash is constant so it can be accounted for in the software. As I say, this is almost identical to how it was originally done on the three axis machines, however, it has proved difficult to employ a belt drive to the worm shaft due to differences in the head castings - see drawings.Last edited by Agathon; 27-02-2020 at 02:21 PM.
Toolbox Refurb - New Handle Fittings
By Wal in forum Metalwork Project ShowcaseReplies: 4Last Post: 22-09-2016, 10:26 PM -
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
RFQ: CNC Myford Conversion
By Jconway651 in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-10-2014, 09:52 AM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM
