    Morning, what cutting tool is best to use on acrylic sheet?
    Thank you
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,194. Received thanks 85 times, giving thanks to others 58 times.
    Single or 2 flute sharp cutter. Look at APT's website for something that will suit.
  3. The Following User Says Thank You to Chaz For This Useful Post:
    definitely recommend single flute, will make your life easier.
  5. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  6. #4
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 9 Hours Ago Has been a member for 6-7 years. Has a total post count of 603. Received thanks 83 times, giving thanks to others 0 times. Referred 1 members to the community.
    single flute "O" flute.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  7. The Following User Says Thank You to Ger21 For This Useful Post:
  8. #5
    Thank you so much for all the replies, i've got both single and two fluted ones.
    kev
  9. #6
    Fred's Avatar
    Lives in Reigate, Albania. Last Activity: 24-04-2018 Has been a member for 2-3 years. Has a total post count of 34. Received thanks 3 times, giving thanks to others 1 times.
    Also, make sure you use cast rather than extruded acrylic. I find that cast cuts really well and extruded can melt onto the endmill at the same feeds and speeds.
  10. #7
    In addition, using a little washing up liquid in water provides an excellent cutting fluid and using a 'climb' cutting direction seems to improve surface finish to the cut edge.
  11. The Following User Says Thank You to EddyCurrent For This Useful Post:
  12. #8
    Thanks Eddy that sounds really interesting, will certainly try it out.
  1. Replies: 0
    Last Post: 28-04-2017, 05:38 AM
  2. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 07:15 PM
  3. Cutting forces at the the tool.
    By Spedley in forum Tool & Tooling Technology
    Last Post: 14-07-2013, 11:04 AM
  4. Laser cutting 10mm acrylic?
    By camhguh in forum Laser Machines & Building
    Last Post: 03-09-2012, 11:51 PM
