    Hello
    I was wondering if it was possible to use the standard control board from the Unimat PC for connecting to Linux of mach for spindle control?
    The board has push buttons or direction and a pot for speed control. I seem's possible to remove these and connect the bob directly to it.
    Is it that easy or will there be issues with earthing?
    Thanks in Advance
    You could always use small interface relays for the pushbuttons. Energise the coils from the bob then wire the 'volt free' contacts across where each button connects.
    Not sure how the pot is wired as I don't have a diagram for that board.
    Thanks, I thought the pot would be the hard part. Any info on these lathes is non existent, let alone a schematic.
    I will see if i can trace the circuit. As far as I can tell the motor is under powered and the speed control dosnt offer full torque at low rpm so might not be worth bothering with but thought Id give it a try before getting a bigger motor and dedicated drive.
  1. SOLD: Emco Unimat 3
    By adrpak in forum Items For Sale
    Last Post: 13-07-2017, 12:02 PM
  2. Emco Unimat Milling Head Conversion
    By magicniner in forum Milling Machines, Builds & Conversions
    Last Post: 30-07-2016, 08:04 PM
  3. SOLD: Emco Unimat 3
    By Boyan Silyavski in forum Items For Sale
    Last Post: 21-05-2014, 04:33 PM
  4. Emco C5 spindle motor control
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 19-03-2014, 03:20 PM
  5. EMCO Spindle Control
    By Pete92 in forum Spindles & Drive Motors
    Last Post: 06-11-2013, 09:20 PM
