Thread: New start
08-12-2017 #131
No idea who that is.. and I get the feeling I should be glad for it ;)
09-12-2017 #132
More bracket power!
The cablecarrier gets crooked in the end.. but havent fastened all the bolts yet.
Need to shorten some so they dont stick out hehe
The Following User Says Thank You to Nr1madman For This Useful Post:
18-12-2017 #133
Quick question?
Been making my cablechain brackets from 5mm thick steel angle (had it laying about)
Brackets for proximity swithes..
Ok to use 3mm thick aluminium brackets from unknown ali quality?
Guess they have to be resistent to vibrations?
18-12-2017 #134
3mm will be fine, the switches have no mass really so vibration will not be an issue.
The Following 2 Users Say Thank You to Davek0974 For This Useful Post:
18-12-2017 #135
21-01-2018 #136
Not much happening at my end other than a question.
My steppers drives accept both ac and dc.
Is it worth it to do the rectifier and caps to get dc or can I just run ac directly and trust my cheapo drives to have enough capacitans to handle back emf?
The Following User Says Thank You to Clive S For This Useful Post:
21-01-2018 #138
Im leaning towards that route...
There is no way there could be thats big caps in the drives.. so I guess that if I go ac my toroidal transformer will get a beating? Especially since its a 500VA and not overspeced for my application?
21-01-2018 #139
I considered using AC with my my AM882h's but when one of them blew and I replaced it I got an AM882 which is DC only.
I might be wrong here but I think if the drive is rated for AC you wouldn't need caps they're only there to smooth out the DC. That said it wasn't hard I was scared of the PSU build and yes I did blow one up ;) but it really was drill a couple of holes, bolt stuff on and solder 6 wires just double check you wiring and don't plug the wires into the rectifier the wrong way round.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
21-01-2018 #140
Haha ;)
Well Im not scared of the process.. but I got a shitload of smaller caps so alot more than 6 solderpoints :D
Im about halfway through but I cant solder with any kids around.. they just have to touch everything ;)
I figured since the drives provide the motors with dc then some internal conversion must happen in the drives if using ac supply...?
Anyway.. it will look cool if I finish so I guess I will stick to the original plan!
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
