Thread: New start
Page 23 of 41 FirstFirst ... 13212223242533 ... LastLast
  1. #221
    I'm sure the mesa boards are top quality but that would mean Linux?
    Not for me my friend :D
    Is fusion360 still free?
    Seems like only for students now?
    Tried estlcam now this evening and it seems basic but powerful !
    Anyone tried it?
    Or should I hold on with the software and focus on getting movement first ;)
    They actually started making plugins for mach3 but never got past the beta phase it was working but the last posts on the mach forum are 5 years old so one would assume it's been abandoned. Given they had it working it seems a shame they didn't finish the work and bring it to market.
    Fusion is still free
    https://knowledge.autodesk.com/suppo...usion-360.html
    It's annoying that the controllers don't support both linuxcnc and Mach3 it seems it's a case of supporting one or the other.
    I totally get the linuxcnc thing you have to be a sadist to go this route but I've been a casual linux user since 2006 for 6 years I never ran anything else but when I got into cad I had to go back to windows. Also I grew up with a dos prompt so linuxcnc isn't quite so scary.
    Now I have a couple of machines running linux and a couple running windows.
  2. #222
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,193. Received thanks 221 times, giving thanks to others 5 times.
    This is a link to the current website - still looks to be free for "enthusiast" (home/hobby) use.
  3. #223
    Thanks to both of you :D
    I must have clicked wrong to get to the educational license...
  4. #224
    NO 100% NO the sooner you learn the Software side the better, both Cad/Cam and controller. Think of it like giving a Kid toy for Xmas without any batterys.
    Nothing worse than having working machine then saying "Now what.!!!"
  5. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  6. #225
    Im actually starting to get some good results in solidworks for CAD.
    Tried fusion before and will give it another try.. tried rhino aswell but that was hard!
    For cam Im really liking estlcam. Played some with cambam but it's not working out like I plan ;)
    Uccnc will be another thing! CAD and cam I can do indoor with the wife and semi communicate with her while learning. Uccnc is in the shed with the machine so any time spent "learning" will be time away from wife and kids. That's gonna be something to make up for :D
  7. #226
    You need to be more annoying then your wife will send you to the shed to calm down ;)
  8. #227
    Where did you find that because I'm sure that's one I've drawn up in the past for someone or modified version of it.! . . . . .Not bothered that you have it just curious where or how it got there.!
    Just wanted to ask, since it might be your schematic.
    Why does the enable signal go through two relays? The coil of the enable relay is driven through master relay.. Why not take the enable signal straight to the master relay? ( I've done this temporarily now)
  9. #228
    In all honesty I don't know. It's not something I would normaly do so maybe the OP added it. You certainly will be fine running it thru master relay.
    The reason I think it's mine is because there are parts of it like the master relay which I drew and recognise. if you notice there are 6 contacts but it states 4PDT. However there are bits I don't recognise and wouldn't use, like that enable relay, so maybe I've helped someone with basic setup which I often do then they have added to it.?
  10. #229
    Uhu!
    Just got to thinking about enable.
    Doesn't do very much to have it through master relay as the e stop already is in that loop.
    Estop would cut power to drives so no point in cutting enable as well?
    Will remove it :)
  11. #230
    Quote Originally Posted by Nr1madman;
    100886Just got to thinking about enable.
    Will remove it :)
    To be honest I never use the enable on steppers unless I want to keep holding torque on motors. For instance in Limit situation
    Limits are not an emergency situation so no reason to kill power to the drives but sometimes, like with a heavy Z axis, you will want to keep holding torque.
    In this case I'd use the Enable in series with Limits.
    Otherwise, I just don't use it because of not much point with steppers.
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
