    Hi, all.
    Finished building a new bench top router and am having the following problem. When I power down, the Z axis drops until it hits something. The Z has 25mm Hiwin rails and carriages, and weighs about 35 lbs. It is powered by a Clear path nema23 driving a 1605 x 350 rolled thread ball screw, supported at both ends.
    What is the best option for stopping this? I hate to add a spring to the side as this would eat up X travel.
    If I turn off the motor enable power it drops very slowly, but killing the power to motor allows it to drop fast enough to hurt you if you got in the way. I gotta fix this. Your ideas are welcome.
    Ben
    Hi Mr.ben I have infeeling that your stepper motor is faulty or wired wrong? When a stepped motor has its pairs correct the motor won’t turn unless it has a signal to move, so when you power off you shouldn’t have the z axis drop, sorry I can be more helpful but I’m confident you have a problem either with the stepper motor or how it’s been wired up
    Hope this helps 👍🏼
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Sam0117 View Post
    Hope this helps 👍🏼
    This statement is incorrect. When a stepper is not energised it can free wheel and will when the Z is heavy. Some machines have an electric brake on the Z motor for that reason.
    He's using a servo, so it's not relevant.
    What you really need is a servo with a brake.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    As pics
Name:	Stepper with brake.jpg
ID:	25433   Click image for larger version.
Name:	Servo with brake.jpg
  1. Triac VMC Servo // Z-Axis Dropping on power off
    By danielbriggs in forum Machine Discussion
    Last Post: 09-07-2018, 10:35 PM
  2. FOR SALE: 4 Axis CNC power distribution board - CNCPDB
    By TadasM in forum Items For Sale
    Last Post: 02-12-2017, 07:02 PM
  3. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  4. Replies: 0
    Last Post: 18-06-2012, 11:15 AM
  5. Replies: 0
