Page 3 of 3 FirstFirst 123
  1. #21
    You could​ probably get a lot more torque on low rpm by using proper vector vfd. I dont know if chinese make any, oh and I have seen limit for vector use of vfd on max 200hz, so its worth checking into that before you spend bunch of money. BTW vector vfd is usualy more complicated to parameter properly, but with WC spindle you should have plenty of torque on low rpm. all of this is without hands on on chinese spindle so I take no responsibility for bad advice
    Poslano sa mog MI 5 koristeći Tapatalk
  2. The Following User Says Thank You to kresimir.cihak For This Useful Post:
  3. #22
    correction, you would need sensorless vector vfd
  4. #23 My first CNC build WIP 120cm*80cm
  1. RFQ: Large bed CNC Mild Steel (500 x 500 x 50)
    By Jono in forum Projects, Jobs & Requests
    Last Post: 03-04-2017, 05:05 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Replies: 0
    Last Post: 16-06-2013, 01:33 PM
  4. High speed spindle for Sieg X1
    By ecat in forum Spindles & Drive Motors
    Last Post: 29-03-2012, 08:56 AM
  5. High speed spindle
    By leadinglights in forum Tool & Tooling Technology
    Last Post: 27-04-2010, 09:23 PM
