Thread: servo cables?
    Ive just bought this ac servo motor and matching drive.
    There are no cables but I have bought the connectors and was going to make them up. Looking around I have seen a few threads that say to make sure the cables are included. is there a reason why I cant make them up?
    Lives in East Lothian, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    Main reason is getting the correct connectors can be hard and/or expensive.
    The other thing is for reliability, you really want them to be crimped, and not soldered. The proper crimping tools are usually very expensive. Soldering will work, but you run the risk of wires fracturing due to solder creep and wire vibration/flex.
    And that's before you consider getting the correct type of cable.
    Ah, I see.
    I have the connectors but yes they are quite small, its only for the encoder and pc connection so is it that critical on the cable? its a short run to the controller and spec just says to use twisted pair.
    The main motor connectors are screw terminals.
    No problem soldering the connectors. Depends of course the exact connector type.
    You will need a proper soldering iron, if you dont have buy this one is the best buy for the money, no need to browse the hundreds of reviews. thats the one CXG 936D EU Plug 220V 2in1 LCD Adjustable Temperature Digital Electric Solder Iron Soldering Station
    If you go for crimping Paron® JX-D4 Multifunctional Ratchet Crimping Tool 26-10 AWG Terminals Pliers Kit
    The cheapest /quality/ cable you could buy from TME , Helucabel The link points to the 12core, you could find there the right one for you
    The connector names you get from last page of servo manual usually
    I think that covers it all. I have bought and have all of the above.
    I have a temp controlled soldering station and the crimps as well so I'm good to go.
    Not sure those crimps will work on the IDC ribbon connectors I have bought?
    Do you have the lcd display for setting them up Boyan?
    IDC ribbon connectors I normally use a vice. I have used pliers and mole grips in the past, but it's better if you can get the whole connector to crimp square and at once, with control over how quickly the connector closes.
    Boyan, those crimping pliers won't cover that many connectors. I've got a set with 12 interchangeable jaws, and it still doesn't cover everything I need it to. I spent most of my life dealing with vehicle electrics, and some terminals just won't work without the correct crimping jaws. And although soldering will work, as I said in my previous post, you risk the wire fatiguing and breaking, especially if it's done poorly.
    Unless the connector is designed to be soldered, I would never personally solder it.
    Best case scenario if a crimp/solder joint/wire fails, is things stop working. Worst case is the drive and/or motor gets destroyed.
    Ultimately how well any method will work, will depend on the final implementation. A cable that is well secured with minimal vibration, doesn't have the same risk of failure as something being constantly vibrated and flexed.
  1. Replacement cables
    By Paul B in forum Chinese Machines
    Last Post: 25-04-2017, 11:24 AM
  2. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  3. FOR SALE: Pack of Omron servo drivers + cables
    By albertoro in forum Items For Sale
    Last Post: 25-01-2015, 12:19 PM
  4. Which cables to shield?
    By andy586 in forum General Electronics
    Last Post: 02-07-2014, 04:33 PM
  5. USB repeater cables
    By Web Goblin in forum General Discussion
    Last Post: 21-05-2011, 12:36 PM
