Have you checked the pulse width from the UC400 ETH?, I don't know how but I've noticed its an option in the UCCNC software. The AM882 needs >2.5us for reliable operation. Worth a look?
25-07-2017 #2
Does the power supply have enough output!
Peter
26-07-2017 #3Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
26-07-2017 #4
Using 50 khz , .1 sec com buffer, and 300 line look ahead
26-07-2017 #5
Driver PSU voltage: ???
Micro stepping: ???
Stepper current: ???
Speed and acceleration: ???
The AM882 seems to be pretty complex compared with the traditional analogue drivers, are you sure it is been configured right, according to the manual?
Have you checked the signal levels at the AM882 end? How about wiring?
26-07-2017 #6
26-07-2017 #7
What's the benefit of 200Khz?
50Khz gives you a longer pulse width, which can be a benefit with some drives.
The fact that he's had this issue with both Geckos and Leadshines, means it's probably not the drives.
That would point to maybe the power supply, an issue with accel/velocity settings, or a mechanical issue.
You said the motors are very hot? What are the motor specs, and what do you have the drive current set at?Gerry
26-07-2017 #8
My thoughts exactly. I've machined lots of parts often taking an hour or more and motors are never boiling hot. Warm to the touch is the hottest they get. Try turning the current down.
My understanding is that voltage is doing the work and turning down the current will help the other parts of the chain such as drivers and psi. If they are browning out under the load that is easily on the list of lost steps suspects.
26-07-2017 #9
Hi guys... Sooooooooo angry right now !!!!!!!!!!!!!
I just video'd the problem for the first time, it was a vertical travel move, with speed turned down to 50% of my tools recommended speed.
After 8 minutes, the tool lifted vertically while unloaded with a slow retract speed, and the Z height travel jammed for 1/2 a second just before getting to full retract height. then plunged into the part. on the next down shift. It wasn't accelerating, it was at travel speed when it jammed on nothing
The previous other error was not caused by the Z axis, as it was an X axis shift, that also must have had to jam and remain in mid air - and be unloaded for 3-4 seconds wile being sent an X command but remaining Dead still in the X axis, with the Z axis moving up making the tool cut vertically in mid air.
Current Peak is set to 3.5A with Pro tuner in the AM882
Stall detect will not function as my cut speeds are low while I try to figure out what is causing these issues
Motors are NEMA23 381oz/in 3.5A Single Shaft Stepper Motor KL23H2100-35-4A, 0.9 degree.
Power supply is PS-10N68 - 1000W 68V Power Supply running 4 of the above steppers, ( two of the motors would have been on 50% current hold ) when the other motor stalled also.
The final thing is that I tried as hard as I physically could to get the Z and X axis to jam, and i just physically cannot, even with the motors hot............ any ideas?
Remember, they both effectively jammed at travel speed, basically under no load, .... but y?Last edited by dachopper; 26-07-2017 at 03:31 PM.
27-07-2017 #10
...that depends on his settings, which I still have no idea about.
50kHz means maximum 50,000 pulses per second.
So, here is my calculation for my machine:
If a motor, like most steppers, takes 200 steps/rev, using 10x micro stepping means 2,000 step pulses for one rev. The speed is 9000 mm/min which is 150mm/s. To move 150mm with my 1605 I need to turn the screw 30 times, so 30 x 2000 = 60,000 which is obviously more than 50,000 meaning that my MINIMUM should be 100kHz.
In other words, it is not possible to say if 50kHz is enough or not, that depends on his speed, screw pitch and micro stepping settings, but those questions are not answered yet, or I missed that part.
Yes, that could be the issue as well, but even the kernel frequency if it is too low, or in fact, the current settings. Of course, if the kernel frequency is too low then lowering speed and acceleration might hide the actual issue when the solution should actually be raising the frequency. If the current is too low then acceleration and deceleration may occasionally be a problem, while at other times it may work. Can also be that it works on one axis but not another. Of course, if the PSU is not able to deliver the necessary current then that might also be an issue...
I don't think motor temperature is a problem. In fact, I think most people draw the wrong conclusion, put their hands on the motor and "decide" that it is too hot, when in reality, you can't really hold your hand on anything for a longer period which is above 40-50 C. Steppers can get as hot as 60-80C so I would really not worry about that, assuming the drivers are set up right and the motors are designed for that current. In any case, "motors too hot" says nothing without stating the MEASURED temperature.
I had similar issues once and the solution was simple: raised the motor current and the kernel frequency. Problem gone immediately after and never seen it again. Of course, motors got hotter but that doesn't matter, I measured and is still well below the limit.
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Which single stepper for long axis?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 24-05-2015, 08:39 AM -
Connecting BOB one axis to 2 stepper drivers
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 11:56 AM -
Z axis error woes
By HankMcSpank in forum Machine DiscussionReplies: 46Last Post: 18-02-2012, 03:07 PM -
The dreaded task of workshop tidying!
By m_c in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-03-2011, 08:07 PM
