Page 2 of 14 FirstFirst 123412 ... LastLast
    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 30-12-2022 Has been a member for 5-6 years. Has a total post count of 116. Received thanks 16 times, giving thanks to others 21 times.
    VFD's are rated for certain motors. So you might have a 2.2kw motor rating and such you will require either a 2.2kw VFD or higher but it's best to use the same rating. Now what I've been having issues with it my VFD has been nuisance tripping my RCD and thus now having a none RCD circuit wired in to my workshop to stop it due to the current load on startup. Also, go for a water cooled spindle, your ears will thank-you afterwards!
    Rob
    Hi RobC,
    Ahh i see, that makes perfect sense, i just didnt know if there were different types that affected compatibility with other hardware. I have asked the seller a question about how many bearings it has. One thing i am curious about, and that i have done no research on, so am lazily asking you guys. The VFD's do you set their speed manually? On our CMS Machines at work we set all of the within the CAM program, its not a problem if this speed is set manually i was just curious.
    Alex
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Sorry for my lack of education, what do i need to look out for when it comes to the VFD? What differentiates between the correct & incorrect one?
    Ok look at this link it shows the difference in the types of the standard vfd. LOOK at the front of them that is the best way to tell they have a different layout you want the Huanyang inverter
    http://www.ebay.co.uk/itm/TOP-2-2KW-...EAAOSwHnFVvvsm
    You can do either but you have to change the parameters in the vfd I personally have fitted a 10K pot of the front of the vfd, this is very easy and the hole is already there. see this link http://www.mycncuk.com/threads/7388-...hlight=fitting
  5. #15
    Hi Clive,
    Thanks again mate, ok so the one i linked to originally should be good to go as long as they reply to my question about the number of bearings.
    Just wondering now about the weight distribution on the gantry before i start ordering bits.
    Thanks Again
    Alex
  6. #16
    I am not sure about the independent homing, i will need to check that for sure, is this common practise for machines with multiple screws on one axis? Is this to ensure they stay parallel
    If you are using two screws and two motors you will have to use two home switches to make sure the gantry is put square every time you home.
    You can of course use two screws with one motor and a belt driving both screws then one home switch will be fine.
    The choice is yours as there are pro's and con's and much debate between the two types.
  7. #17
    Ok, i need to do some serious research to see if that controller can handle that, i know it provides for 4 Axis but im not sure if the 4th can be setup as Dual Axis.
    So i know i keep banging on about the weight distribution of the Gantry, but i really am being stupid today. It seems at some point i had lost all of the material properties for my assembly parts, ive just spent a little while going through and properly setting the weights of each component, i have based the Aluminium Plates on being a 6061 Alloy, whether or not this will be the material the plates are cut from i dont know, but it was the most common material so i though i would go with that, i re rain the analysis and it has given me a hopefully accurate Centre of Mass for the gantry, indicated by the Red Dot, im hoping this is a pretty acceptable balance and wont cause any undue wear or stress to the linear bearings:
Name:	COM Final.png
    Alex
  8. #18
    Quote Originally Posted by AlexDoran View Post
Name:	COM Final.png
    Alex
    I'm sorry to inform you that the fourth axis on the controller is only rotational and can't be slaved. Have been drooling over it myself but have to go another way as I'm using 2 motors for my X axis. Boyan runs it with two drivers on the same signal but because of that he lost the ability to home separately.
  9. #19
    Hi I had KJN cut and drill my frame (With counterboring) which is a little cheaper than using the corners but also stronger. They will do it to your cad model, you could still use corners as well for extra strength.
    Cost me £35 +vat for 18 holes with counterboring.
    I already had the corners I did it for strength, I used m12 50mm A2 socket bolts.
Name:	Extrusion drilled.jpg
    A top tip if you do what I did make sure you get some corners then use them to get the extrusion straight before putting the bolt in when it's tight you can remove the corner and reuse.
    Also 9045 extrusion takes M12!!!
  10. #20
    I see, i also had this answer in another thread, a couple of the guys thought that it should be fine as long as there are no major crashes and i have a method for adjusting the gantry to be tram.
    That's a good shout, i will be buying my Extrusion from KJN too, i have used them in the past! Are brackets alone not rigid enough do you think?
    Alex
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
