Page 7 of 20 FirstFirst ... 5678917 ... LastLast
  1. #61
    The epoxy pour looks really good!
  2. The Following User Says Thank You to Nickhofen For This Useful Post:
  3. #62
    Quote Originally Posted by Nickhofen View Post
    Well... need to say...
    Disaster
    Something went wrong ....
    There was a tiny leak.
    It leaked on the surface of Xaxis... it sucked inbetween the gantry and bed...
    I did make preparations to prevent this.
    I sprayed wd40 inbetween before pouring.
    So nothing could stick.. worked only partially.
    I needed a hammer an chisel to separate the gantry from the bed.
    1 side of the x bed surface delaminated from the steel ....destroyed .
    So deep breath ... cleanup and do it once more...
    Grtz Bert.
  4. #63
    I am sorry to hear about that.
  5. The Following User Says Thank You to Nickhofen For This Useful Post:
  6. #64
    Quote Originally Posted by driftspin View Post
    Yes super happy with it.
    Need to do some mesurements to check for obvious F ups ...
    Only have some old analogue calipers ...
    Need to start buying some quality measurement tools help with aligning the rails.
    And i am hoping piano wire can help with aligning...
    I have some quality 140cm 8040 profile that can be used with straightening stuff.
    Bouyan said one needs a 1000mm straight edge and machinist squares..
    He is right i think...
    Need to start figuring this out.
    So...
    I am about to order linear bearing parts.
    Final BOM :
    Rail**
    2pcs*HIWIN*HGR20-L1830mm*Linear*rail
    2pcs*HIWIN*HGR20-L1000mm*Linear*rail
    2pcs*HIWIN*HGR20-L500mm*Linear*rail
    8pcs*HIWIN*HGH20CA*Linear*carriage
    4pcs*HIWIN*HGW20CC*Linear*carriage
    Ballscrews*rolled*C7.
    End*machining*fixed*float*for*a*pulley's
    1set*C7*RM1605-L350mm*Ball*screw*with*ballnut
    Change*Length*F*to*30mm*
    1set*C7*RM1610-L1150mm*Ball*screw*with*ballnut
    2*sets*C7*RM2010-L1700mm*Ball*screw*with*ballnut
    2pcs*1610*Ballnut*Housing
    2pcs*2010*Ballnut*Housing
    4pcs ballnut grease nipples
    2*sets*superior type*bk*bf12*1610
    2sets*superior type*bk*bf15*2010
    Any thoughts?
    Grtz. Bert
    Bom ordered BST Fred.
    Anyone with experience from NL here?
    I am curious about how this will work with dutch customs..
    I understand carrier will report to tax administration..
    My estimation is about 27% extra cost.
    21 vat 5 import and some minor handling cost.
    Guess i will pay tax and handling cost to carrier..
    Grtz. Bert
  7. #65
    Grtz. Bert
    So... guess what the post man brought today.
    Goodies from china.
    Guys, thanks for recommanding Fred from BST.
    Everithing looks good and well packed.
    Some heavy cardboard box reinforced with multiplex all wrapped in plastic foil.
    2nd attempt at pouring epoxy is underway.
    Tomorrow ill visit the local tool station to go and get m5 machine taps and some nico 4.2 drills.
    Also.... need to source some Alu tooling plate. for gantry.
    And have some 20mm mdf cut for test fit.
    Its gonna be busy holidays.
    Grtz. Bert.
  8. #66
    Nice goodies Driftspin!
    It seems that Christmas came early ;-),Merry Christmas !
  9. #67
    Grtz. Bert
    What did you end up paying to your door if you don’t mind me asking?
  10. The Following User Says Thank You to charlieuk For This Useful Post:
  11. #68
    Quote Originally Posted by charlieuk View Post
    What did you end up paying to your door if you donít mind me asking?
    Well i am not sure yet.. fedex delivered... i paid Fred... But i have not been taxed yet..
    I guess it will be in the +/- 1300.- euro range.
    I understand sometimes you pay tax in the country where goods enter EU.
    That would be belgium..
    Grtz. Bert.
  12. #69
    I ended up paying 1200,- euros..
    Fedex charged 10+10 euros costs +
    i Payed about 31% import tax / vat on 480 usd shipped value based on attatched dispatch note.
    Grtz Bert.
  13. #70
    Top Z carriage position.
    Hi guys..
    I am doing 15mm plywood test fit for all Z axis alu plates before ordering.
    Where did you mount your top carriage?
    High or low? And why?
    Grtz Bert
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 30-01-2017, 12:37 PM
  2. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. BUILD LOG: First steel diy CNC router build
