04-07-2018 #181
Noise?, okay, with an unshielded connector and a (very) poor connection. More likely, you'll be introducing resistance , and that will have a detrimental effect on the machine (whether measurable, is something else - if the PSU is spec'd correctly and the drivers are in constant-current then it should will have a limited effect).
It is a balance between cost and convenience first and foremost. If I had a cabinet with the holes for the steppers pre-drilled (as appears to be the case in that impeccable cabinet) then I'd go connector. If you never disconnect them, then the convenience never comes into play and you've lost the cost of 6-12 connectors over the life of the machine. If you have to disconnect them then, without the connectors, you're suffering inconvenience each time. It also helps to be able to isolate cables from cabinets during construction, installation, maintenance, etc.
Call me lazy - I prefer to make life as easy as possible for myself.
Sods law : if you provide connectors - you will never move it. If you don't - you will :)
Remaking screw terminals is not a great use of time - you shouldn't re-use the existing wire/crimp without remaking (I would re-use, in the knowledge I'm doing wrong, again out of laziness - it'd bite me in the end).
Absolutely.
My only caveat on my view above - I'd make sure to use a vaguely appropriate connector.
The Following User Says Thank You to Doddy For This Useful Post:
04-07-2018 #182
Oh connectors. No i was thinking using the bottom row of terminal blocks or not.
So lost time while moving is not in the equasion then. it is both screw terminals.
I agree with you on the resistance issue, it is to be avoided. also connectors if not done right are an other source of errors.
So straight to the drives it is.
Thanks guys
I think Doddys first paragraph sums it up better than my quick description
I’ve had good experiences with connectors- My first CNC machine used aviation connectors and I had no issues with them at all so it can work fine.
I’ve also had bad ones where the connector to the spindle flashed over and blew the expensive VFD. Totally my fault as I didn’t provide much strain relief and the spindle moves around.
So I just have an aversion to them which is probably not very scientifically based when you do it right.
In terms of time spent disconnecting the steppers the drives usually have a green terminal plug which you just pull out and feed out of the cabinet so it comes down to how easy it is to feed the cable out.
14-08-2018 #184
Hi guys,
I was finally able to make some progress again today.
Now a new question ...
Does UCNC work with soft limit end switches?
For the y & z i am able to do home end switches both ends..
In my design it is al lot harder to do x1 home and end, and x2 home and end.
So just home switches on x1 and x2 ... is that enough?
Grtz Bert.
20-08-2018 #185
Hi guys finally,
Things are moving
https://youtu.be/DGThYTQ_QdE
Scary stuff, this thing is powerful.
Homing.
So now i am trying to get the combined home / limit switch working.
I played with the softlimit and offset settings.
After homing , this works everytime, the UCCNC software goes to reset because it is at the limit position.
I cant reset until i move all 3 axis out of home position.
Is there a way to automatically backoff from home, to home +5 or so, to not directly trigger limit/reset after homing?
Reading the manual did not point me to a solution yet.
Grtz Bert.
The Following User Says Thank You to driftspin For This Useful Post:
20-08-2018 #187
Hi doddy,
All in all i had to add 500 ohm to 4.7k to have the inputs switch reliably. I ended up at 8.65 volt. after switching the inputs would not drop..
Adding 500 raised it to 9.15 ish. which is ok
So you where right it needed to go near 9 and or slightly over.
0.5volts still illuminated the input opto's just enough to screw up somtimes
I still have a glitch in 1 of the inputs though..
Need to find out why.
maybe wiring issue or a slightly off 4.7k resistor.
ill try 1k instead off 500 first... maybe there is a switching effect or so.
Grtz Brt
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 21-08-2018 at 04:13 PM.
21-08-2018 #188
It looks good from down here Bert
The Following User Says Thank You to AndyGuid For This Useful Post:
21-08-2018 #189
Nifty Job!
The Following User Says Thank You to Nickhofen For This Useful Post:
25-08-2018 #190
Ok more good stuff today.
I got myself started on cad with fusion360.
I will run into walls later i am sure.
But for now i managed to produce Gcode with it and made my first air cut.
So i am really in good spirits now :-)
I do realize now i need a probe sooner or later. For finding the workpiece position without to many f ups.
So i need to wire in my 2nd 5 axis bob.
I used up all inputs. e-stop home switches on x y z and a axis
I do have the B and C axis step en dir output spare on the 1st bob.
Can one use them for any misc purpose?
Maybe i need to get me some 5v coil relais boards soon
Also i need to start work on the bed surface.
Mounting points for a vice and clamps.
And maybe start with pouring epoxy for some basic cuttable surface to level the surface on the crossmebers.
Question.
Did you guys put your cutters all in the F360 library?
And does F360 do a good job on estimating feed speed doc and step over?
Somehow i feel a cutter library and a standard probe surface, is pointing in the direction of workpiece holding at known stationairy coordinates...
Can anyone please point me in the direction of best practice?
Probe the actual workpiece everytime or make solid default coordinate workpiece holding pins and vices relative to a stationairy bed probing surface.
Because i have no experience, education or well founded opinions on these things yet, i might just as well ask you all right :-) ?
Grtz Bert.
Verstuurd vanaf mijn SM-A320FL met TapatalkLast edited by driftspin; 25-08-2018 at 11:14 PM.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
By ivars211 in forum DIY Router Build LogsReplies: 59Last Post: 28-07-2014, 08:29 PM
