Page 3 of 3 FirstFirst 123
  1. #21
    I've used the router for an hour with no issue, thank you very much for all the replies, especially you, Clive. I'm not quite sure what happened but I'm (fairly!) confident in saying I'm back in business :D couldn't have done it without this forum!
  2. #22
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by mark84 View Post
    Mark Just for the sake of clarity and for others can you say what was the problem if you know.
    Glad you got it going.
  3. #23
    Sorry for my wall of text, I misunderstood the original instructions about joining For and Dcm, I didn't think you meant with mach 3 connected.
    I can confirm that connecting these two and starting the toolpath does bring the spindle to life, disconnecting the two while the spindle is running stops it, and simply pressing the spindle off via mach3 slows it(but doesn't stop it fully) to about 70rpm.
    I know this is a very big bump, but I've just put it to the back of my mind for the best part of 3 years (where does the time go!)
    So I'm still to this day happily using the router(an hour or so a month) with FOR and DCM connected. Everything works fine *touch routed wood *, so I never altered the vfd settings, and just stuck with the change to the wiring.. but can I ask if this solution has any downsides?! Should have probably asked this in 2017.
  2. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  3. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  4. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
