Hi. I'm a newbie on this. I have a maxicam cnc router with a max spindle speed of 18000rpm. I'm wanting to cut 18mm birch ply in 1 pass. Current setup is 18000 spindle speed with a feed rate of 3500mm/min using a 2 flute 12.7 compression cutter in 2 passes. I feel that the machine can do more and the cutter is capable of 1 pass. Can you guys advise on this. Cheers
