Page 1 of 6 123 ... LastLast
    HI has anyone come across this problem with Mach3 I did a design in aspire and set my machine up but found it carved the image twice the second on off set by approx 30mm I have attached an image to show what I mean so I would ask it to draw 1 circle but I get what is shown on the attachment, thanks guys.
    Does the Mach3 toolpath screen show two circles? Does the Aspire preview?
    Can you post the g-code?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Quote Originally Posted by woodworker View Post
    Check which post processor you are asking Aspire to use to save toolpath, try Gcode (mm) (*.tap) should work on most machines.
    Phill
    Thanks for the response, I don't have the gcode but next time I will save it the image looks correct in both aspire and on the mach 3 display.
    Will try that Phil cheers
ID:	23011Click image for larger version.
ID:	23012Click image for larger version.
    Hi Guys managed to get 5 mins down the shed, haven't changed the settings or file format saved as mach3 format. Asked it to do a pocket cut on a piece of wood cut size 70mm x 70mm found on third pass it changed the start point 15mm to the right it does this on text as well. Gcode below (sorry couldnt find another way to post it :) ) I'm using aspire 8.5 and Mach 3 cheers Thanks again
    Well the code looks good to me every time the Z drops down the X and Y start at the same place.
    I would suggest you have a mechanical problem or you are missing steps. pulley loose etc. binding up!!
    It might be better to post the text as a file attachment to save space.
    Hi Clive no binding bud just tried saving as a Gcode file (recommended by Phil) instead of Mach 3 have a completely different issue so I'm thinking compatibility issue with the hardware software think I will email Rhonmac.Click image for larger version.
    Did the machine come with a DSP or Mach3?, check if the Rhonmac machine needs it's own post processor.
    Phill
    No software came with it the guy used to use linux OS I am not a fan of it so I put all the software on :) probably why it doesnt work lol
  1. 3d carving oak
    By Mikeb in forum Woodwork Discussion
    Last Post: 24-03-2014, 10:22 AM
  2. V bit carving
    By Mikeb in forum Tool & Tooling Technology
    Last Post: 20-02-2014, 04:52 PM
  3. tools for 3d wood carving
    By chris in forum Marketplace Discussion
    Last Post: 18-01-2014, 04:23 AM
  4. 3d carving bits
    By drut in forum Tool & Tooling Technology
    Last Post: 04-07-2013, 01:03 AM
  5. Microcarve picture carving software
    By cnctoybox in forum CAD & CAM Software
    Last Post: 26-03-2012, 07:00 PM
