    I've recently moved to smaller premise and i'm instantly noticing the plasma fumes, much more noticable that mig fumes, even though I have a water table on my cnc table.
    I'm wondering where is the best place to extract from, the width of hood and fan size. I can either add a hood at the cutter or make a larger hood to cover the whole 4x 4 table and extract from a single apex point. Currently have a lot of 6" 150mm hose should that be a good diameter.
    Any ideas or links welcome.
    I suggest the following
    Face area of table 2.5M x 1.25M x 0.75 = 2.34m3/s or 8437.5 m3/hr
    That would give a fan and ducting size of 630mm diameter.
    The 0.75 m/s comes from the HSE recommendation for venting of plasma tables.
    I went for something smaller as I did not want to cut that size hole in the wall, so I went for 500mm diameter and uprated the fan to move more pressure. It's louder but I can vary the speed as required.
    I vented from under the table, to prevent the finish face from discolouring etc.
  3. The Following User Says Thank You to philgrady For This Useful Post:
    How does your table work?
    Industrial tables usually have water baths which significantly reduce emissions to the workspace.
  5. #4
    That's great advice, thanks.
    I currently use a water table, which is a 100% necessity with plasma. TBH I use the plasma infrequently but when its on it runs on and off all day. i'll probably have to use a standard 300mm dia hose because thats the max exhaust size I can use to the outside. Will extend the hood and fan power accordingly.
  6. #5
    On my 4' x 2' table I boxed in 3 sides and created a duct for the 4th side fitted with a 6" flexible hose connected to a 1.5 HP 3000 rpm centrifugal fan exhausting outside the workshop. I drape fireproof blanket over the gap between the workpiece and the table edges so most of the smoke and fumes are extracted downwards.
  7. The Following User Says Thank You to Bladevane For This Useful Post:
  8. #6
    Quote Originally Posted by Bladevane View Post
    Nice 1, fire blankets a good way forward
  1. dust extraction for foam
    By charlieuk in forum Dust Extraction & Collection
    Last Post: 09-12-2014, 10:25 PM
  2. Need More Suction on the extraction
    By adamh in forum Dust Extraction & Collection
    Last Post: 02-07-2014, 10:37 PM
  3. Cyclone extraction
    By gorbo in forum Dust Extraction & Collection
    Last Post: 17-04-2014, 05:36 PM
  4. What CNC Router and Extraction will suit my needs?
    By flightcase01 in forum Gantry/Router Machines & Building
    Last Post: 27-08-2011, 11:00 AM
  5. System spec and Mach3
    By gorbo in forum Computer Hardware
    Last Post: 23-01-2011, 03:25 PM
