Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    Quote Originally Posted by wallyblackburn View Post
    No, it was also proper hell also! I'll use packing tape backwards next time as Clive and others suggest...
    I was not aware of this requirement.
    Never had thought of this simple solution myself.
    I will use cheap packing tape for my pour.
    thx guys.
    Grtz Bert.
  2. #22
    Got the rails and ballscrews for Y-Axis from Fred at BST. Got epoxy cleaned up and mounted first rail. Tried to rough-align second rail using some equal length bars between them and could not get them lined up. Took one off and put it on my surface plate. Nice and flat on top and bottom, but crooked as a politician in the horizontal plane. Getting 12 thou out towards ends.
    Thinking this is to be expected when you pay $282US for 2 rails, 4 trucks, and 2 ballscrew assemblies. Anyway, guessing some others have dealt with this? What did you do?
    I'm thinking of tightening down in middle, and then working my way out trying to pull the rail to a straightedge and cinch it down. Maybe make a saddle kind of jig that will give me a screw to adjust the rail before tightening it down. Sounds dodgy.
    Thoughts?
    Wallace
  3. #23
    Hi Wally
    Nice work with the pour, i explained this a while back but have not been able to find the thread it was on, but you are correct, fix the centre of the rail first then work your way outwards setting your rail to your straight edge, clamping the rail, drilling and tapping and then securing as you go.
    Regards
    Mike
  4. #24
    Allow me to retract at least most of my last entry and apologize to our Asian friends. Oh...and admit to being a dope that goes off half-cocked...
    I was looking at the edge along the base near the mounting surface - which is not really a reference surface, I don't believe. In checking the side of the rail where the balls ride, I get less than a thou over any 6-8 inches. At this point, I am just going to start on the gantry mounting and check it at different points as I go.
    Regards,
    Wallace
  5. #25
    I think you will find some marking on the rail depicting the master/reference edge, once you have that set to your straight edge it would probably be better to use your gantry to align the second rail.
    Mike
  6. #26
    Regards,
    Wallace
    This is how I did it.
    First rail as straight as possible then I mounted the gantry and slid it back and forwards as I was drilling.
    Then I took it off and tapped all holes.
    Then remounted for tightening the screws and worked as close to the gantry as possible :)
    Skickat från min SM-N910C via Tapatalk
  7. #27
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,193. Received thanks 221 times, giving thanks to others 5 times.
    I have a feeling that that is also suggested in the Hiwin manual. Certainly worked for me!
  8. #28
    Oh! Haven't read that one..
    I have noulei cheapo bearings (no manual) ;)
    I read the mycncuk diy manual. It's quite a read but lots of good pointers.
    And the best part.. it got pictures! :D
  9. #29
    Neale's Avatar
    I did read the manual but all the warnings about how accurate you need the mountings to be worried me so much that I closed the manual and just carried on anyway!
  10. #30
    That sounds sane! Sometimes you just have to check what works hands on..
  1. "Hacking" and "Modding"
    By magicniner in forum General Discussion
    Last Post: 07-01-2015, 08:59 PM
  2. Cnc router wood "roughing bits" anyone used these before?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 27-04-2014, 10:11 PM
  4. "Racks" VS "ball screw"
  5. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
