Page 8 of 8 FirstFirst ... 678
  1. #71
    Lives in Plymouth, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    I use those litle 4-way connectors for signal connections (limit switches, etc) - they are fiddly to wire, aren't they?
    For stepper connections, I personally use 4-way XLR latching connectors, which are a bit chunkier to handle! Not sure what other people use but XLR are readily available and not too expensive compared to some of the more exotic connector types.
  2. #72
    A little more modern to boot. I just took another look at the spindle connector - it is actually a larger version of the 4-pin mike connector. Doesn't look too bad to solder to and seems a bit heftier.
    Decided to affix the spindle to my surface plate and check it out while I was messing with it. The inner contact surface of the spindle is nuts on - I get under a tenth of runout - very nice! The included collet, not so much. More than 2 thou (once the needle on my tenths indicator starts moving that much, I don't bother to get an exact measurement). Probably worrying too much for a primarily wood machine, but that collet goes in the trash. I'll order a Lyndex or Royal...
    This is getting fun!
    Wallace
  3. #73
    First cut! The requisite circle :)
    Still so much to do, but that is definitely encouraging!
    Regards,
    Wallace
  4. The Following User Says Thank You to wallyblackburn For This Useful Post:
  5. #74
    Wally!
    Good work and well done :D
  6. #75
    More test cuts. Doing calibration.
    Thanks,
    Wallace
  7. #76
    Nice, looking good.
    Is that a Fusion tool path??
  8. #77
    Nice, looking good.
    It is. I have to say, of all the hurdles so far Fusion 360 has been the biggest. But, I am finally starting to get the hang of it.
    Makes sense, I suppose. I have lots of experience with building stuff and electronics. But, CAD is new to me.
    Thanks,
    Wallace
  9. #78
    Its a steep curve but once you get over the top, the fun really starts - there is great satisfaction in designing a part in 3D then converting to tool paths and watching your machine turn it out. :)
  10. #79
    Yes it is!!! I made a dust shoe top! Getting ready to try the bottom here in a few.
    Thanks,
    Wallace
  11. The Following 2 Users Say Thank You to wallyblackburn For This Useful Post:
  12. #80
    Well, I'm at the point of cutting real stuff:
    And - of course - thinking about what I want to do to make this one better AND what I'll be doing for the next one! :)
    I am leaning towards a 4x8+ made out of extrusions. Wood-only, so I think extrusions will be fast and adequate. Want to be able to put a whole sheet of plywood on at once. But, just thinking/dreaming at this point.
    For this one, I am planning the following:
    - 1/2" steel table with a 3/8"-16 hole pattern for bolting down MDF wasteboard, Aluminum pieces, etc.
    - 3 or 4:1 belt drive on X- and Y-axis. The X and Z are direct connected. The Y is belt, but 1:1
    - More rigid gantry with 1/4" steel end plates and 2040 Rexroth crossbars. With a slanted design to allow more real estate to be accessible
    - Maybe filling some of the frame members with something - mortar maybe? Sand?
    Thanks to all for the advice gotten here,
    Wallace
  1. "Hacking" and "Modding"
  2. Cnc router wood "roughing bits" anyone used these before?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 27-04-2014, 10:11 PM
  4. "Racks" VS "ball screw"
  5. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
