Thread: Aluminium profile CNC
Some update of the design. I've lower the extrusion side, add an extrusion on the bottom of the x axis, moto mount and the side plates.
As usual if anything seems to be wrong don't hesitate to comment :)
The ballscrew of the X axis is now higher to screw it directyl to the bearing plate. Thanks Jazz!
I don't add it but the cable chain will be on top of the 120X40 extrusion.
The Y axis motor mount plate:
To mount the ballscrew, I will use a separate plate. I think it will be easier to adjust if necessary.
If you see anything, please let me know :) Thanks
16-04-2018 #2
Is there a standard way to fix two pieces of extrusion?
I search on the forum and found this:
http://www.mycncuk.com/threads/4513-...2346#post72346
maybe another idea?
03-07-2018 #3
Hi BriceO
Did you ever solve your problem? In this link this is how I solved the problem by drilling a hole through the extrusion so that I could tighten the bolts in the clips. It is very solid and has not moved in 2 years!
03-07-2018 #4
Aluminium profile cnc build
By valdis034 in forum Gantry/Router Machines & BuildingReplies: 84Last Post: 21-02-2023, 02:27 PM -
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
