Thread: Cnc 3040 z ball screw
09-11-2017 #1
Hi
Doesn't anyone know the spec of the vall screw on the z axis? The bushing on mine has broke the nylon washer had fell and some mini bearings have fell out.
See pic
Sent from my SM-N910F using Tapatalk
Hiya,
The best thing to do is strip it all down and clean it up, once you've collected all your balls, count them and measure their size, once you know this you can look at replacement balls for/if any are missing.
I can't remember for sure what screws are used on these machines but I'd bet they are just 1605 ballscrews, again you can measure the screw diameter to confirm this and once we know all this week can advise on what's what.
13-11-2017 #3
13-11-2017 #4
If it is a standard ballscrew I can't see how a ball bearing could escape unless the plastic return guide has broken. Wonder if the balls have jammed inside and pushed it out.
If you can do as Lee suggests and remove the ballscrew it will help identify it.
When laid out in the bench measure the diameter of the screw and then measure the pitch (distance between peaks or troughs). Also measure the diameter of the ball bearings (micrometer ideally) and take a picture of everything including the ball nut.
From the picture you have taken it does not look like the usual Chinese ballnut
The Following User Says Thank You to routercnc For This Useful Post:
13-11-2017 #5
14-11-2017 #6
Ok that's better. The first picture was of the supported bearing end not the nut - now we can see the ballnut it is a standard Chinese type.
Ballscrew is most likely 12mm and the pitch looks like you have measured between a peak and a trough. Needs to be between 2 peaks OR 2 troughs so it is most likely 5mm. So you have a 1205 ballscrew and nut.
You can try to buy just a new nut but they come as a matched pair with the ballscrew and the ball bearings are sized to be a good fit. That means another random nut may be too tight or too loose on your ballscrew. Unless you have a tuning set of ball bearings your best bet is to strip the nut down, clean it, grease it and reassemble with missing ball bearing in. Chances are it was clogged up inside and jammed the return channel. Have you ever greased the nut?
When you remove the nut watch out for the remaining balls which will fall out. You will also need a guide tube to sit over the floating end of the ballscrew to guide the nut off and back on again. Once inside the nut look for damage to the plastic returns.
The are videos on YouTube about repacking ballnuts
14-11-2017 #7
Ball screw advice
By Darren in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 10-04-2016, 10:52 PM -
How to machine a ball screw
By Tom_Nelson in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 22-07-2015, 10:50 AM -
Ball screw
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 20-10-2011, 01:28 PM -
WANTED: 12mm ball screw & nut
By phill05 in forum Items WantedReplies: 8Last Post: 22-06-2010, 09:26 PM -
Stationary Ball Screw
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 14Last Post: 29-12-2009, 01:12 PM
