    First real post! Looking for advice on moving gantry design.
    Proposed machine cutting area: 1220mm x 1220mm cutting area (1/2 plywood sheet)
    Materials to be cut: Foam, Hardwood, Plywood, Aluminum to 6mm thick.
    Proposed machine parameters:
    Floor standing
    Moving gantry with high wall frame
    Gantry beam length about 1500mm
    Twin X axis ballscrews, single Y and Z
    Non-production environment
    Need decent but not perfect finish on edges of aluminum plate.
    Would like to hold plus minus 0.1mm on dimensions
    Materials available for the router build:
    80/20 extrusion 3030 (76mm x 76mm)
    80/20 extrusion 1530 (38mm x 76mm)
    6mm aluminum plate
    15mm plate
    20mm plate
    Shop tools available:
    20 inch bandsaw
    Full size CNC knee mill
    Small CNC lathe
    300mm x 300mm CNC router
    Small shear, small pan break, air compressor, die filer, etc.
    Experience:
    Amateur CNC machinist. Built a couple of small CNC routers and some custom automated machinery for pool cue
    builders. Just enough knowledge to be really dangerous.
    First picture is what my design looked like before searching around this forum for a while. Looks like I hit all the usual problems
    such as:
    Separated twin beam gantry
    Ballscrew between gantry beams
    Thin Z axis plate
    Z axis rails not on Z axis plate
    Single gusset plate to hold end extrusions to gantry carriage plate
    Probably a lot more problems lurking in that design. So I am starting over. And the first thing I want to do is to settle what the cross section of the
    gantry should look like using the materials available to me. The second picture is of some gantry and Z axis plate cross
    section views with different configurations of extrusions. Trying to come up with some ideas that combine the recommended
    box or L box beam construction with things I have on hand.
    Do the drawings make sense? Any of my ideas decent? Got any suggestions?
    Thanks,
    John C
ID:	23219Click image for larger version.
Name:	Gantry XSection.jpg
    Consider the information here; http://www.cncroutersource.com/do-it...NC-router.html
    That should be a guide to the best arrangement.
    There was some discussion here about "stiffness", it's a pity more people did not contribute at the time. http://www.mycncuk.com/threads/7155-...stiffness+test
    There may be some merit at looking at the numbers to see what each design offered.
    EddyCurrent, your first reference seems to recommend widely separated unsupported rails for the gantry. That might be better for a smaller CNC than I plan. The second reference concerns measuring the stiffness of the CNC machine after it is built. A great idea but I am far from even starting my build.
    What I really was hoping that someone could advise me on what would be a good gantry design (cross section anyway) using square and 1/2 of square extrusions with using thin plate to box in the beams. Without advice from someone with experience I will probably need to do some simplistic FEA on configurations of hollow rectangular tubes to get a comparison of configurations. Even if I had an FEA program that analysis if done accurately will be somewhat of a task. How about a gut feel comparison of the cross section sketches in my original post?
    Thanks,
    John C
    I think you missed the point in both cases.
    The first link was not to show which components to use but rather the best geometry for success.
    In the second instance, the stiffness, which you want loads of, was measured after the build, as you say, but that gives us the benefit of looking at the designs to see why those figures turned out as they were.
    So now we can either use or avoid those ideas in our own designs.
    Somewhere in this forum is a spreadsheet that calculates various gantry designs, you should find that and test your own ideas out with it.
    Here is the calculator I wrote some time ago if you want to compare sections
    http://www.mycncuk.com/threads/2214-...ess-calculator
    Of the designs you have drawn they all have the ballscrew next to the YZ axis which is compromising the gantry stiffness.
    A popular design here is the L shaped gantry with ballscrew tucked behind. Away from pc so will post example later or someone might post it.
    L
    Ok, thanks to both. Sounds like I need to go back to the math for a while.
    John C
  1. Design for 4' * 3' gantry cnc - help me decide
    By colin2216 in forum Gantry/Router Machines & Building
    Last Post: 17-04-2017, 07:21 PM
  2. MASSIVE 2.5M x 4M BED - GANTRY DESIGN HELP NEEDED!!
    By woodhouse in forum Gantry/Router Machines & Building
    Last Post: 11-07-2015, 05:42 PM
  3. Maving Table Gantry Design
    By Hubert1946 in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2014, 09:21 PM
  4. Gantry design advice please
    Last Post: 07-11-2012, 04:17 PM
  5. Gantry design question
    Last Post: 10-10-2012, 09:11 AM
