    I have a Denford triac which works great, but I would like to mill brass using a 0.6 mm cutter.
    I plan to add a high speed spindle to do this, perhaps just one that bolts on and off.
    I have looked at spindle kits on ebay but I am slightly lost on how many watts my motor would have to be.
    Has anyone got any ideas or suggestions ?
    Have you considered building a "Spindle Speeder"?
    I built a 1" OD belt driven spindle cartridge based on a 10mm shank ER11 Collet chuck, a bit of ally bar and 3 bearings rated for 30000rpm, it mounts on one side of the head and a large pulley on the main spindle gives me around 7:1 speed increase allowing use of very small end mills and engraving cutters at up to 28800rpm. Spindle & pulley cost was around £25 plus a little of my time.
    Regards,
    Nick
    Thanks Nick,
    Have you got a picture of your design ?
    Regards,
    Jeremy
    I'll chuck it together and take a photo tomorrow, my implementation includes a sprung linear slide which allows the use of an engraving spindle with a depth setting nose, this allows engraving to a fixed depth on complex 3D surfaces for which you don't have a 3D model.
    Here's my set up fitted with the ER11 Milling Spindle which I built, it's genuinely an afternoon job and by applying the principles in Harprit Sandhu's book on spindles I came up with a design using a pair of bearings at the nose which are bonded to both the spindle and sleeve and a top bearing which is bonded to the spindle only and is a sliding fit in the sleeve.
    The pulley on the mill spindle gives 4.7x which gives a theoretical 32900RPM top speed with my mill's 7000RPM top spindle speed, the belt is round polyurethane, bought by length and welded with a disposable gas cigarette lighter ;-)
    You don't need a slide but I used the Deltron slide modified to micrometer adjustable spring loading to allow the use of a spare micrometer depth controlled spindle which came with my Gravograph IM3 shown fitted here -
    The engraving spindle has an adjustable "nose" which is micrometer adjustable to allow a precise amount of the cutter to protrude, by applying spring pressure on the slide the engraving spindle nose will follow uneven and curved work surfaces maintaining a fixed depth of cut, the nose fitted incorporates a spherical follower which is very good for maintaining depth of cut over significant changes of surface angle, up to around 30 degrees -
    Springing also allows "Diamond Drag Engraving" without the spindle running,
    This is the milling spindle -
    It's had 40+ hours of run time with no sign of any issues.
    Post any questions you have and I'll do my best to give a useful answer,
    Regards,
    Nick
  1. Choosing a high speed spindle
    By GND in forum General Discussion
    Last Post: 10-10-2018, 12:37 AM
  2. High Speed Spindle - Drilling & Mild Steel
    By Chaz in forum Spindles & Drive Motors
    Last Post: 29-07-2017, 07:09 AM
  3. Replies: 0
    Last Post: 16-06-2013, 01:33 PM
  4. High speed spindle for Sieg X1
    By ecat in forum Spindles & Drive Motors
    Last Post: 29-03-2012, 08:56 AM
  5. High speed spindle
    By leadinglights in forum Tool & Tooling Technology
    Last Post: 27-04-2010, 09:23 PM
