  1. #31
    if its ethernet, how can it be LPT??
    It talks ethernet to the PC, but instead of direct outputs like the CSMIO range, it has a set of 5 "parallel port" style output connectors. In fact, they are standard PC board headers and each needs to be connected (simply) to a terminal strip (or cheap BOB as the connectors carry the same signals as a parallel port) to give access to the connections or (much better) to a custom BOB which provides opto-isolation plus the potential for 24V signalling. There is a fancy BOB specifically designed to go with it that provides opto-isolated access to all its IO ports. Not sure if it can also handle differential signalling for connection to stepper drivers. The combination isn't cheap - the BOB costs as much as the controller board, I think, but the combination plus UCCNC is competitive with the IP-M if you also add in Mach3.
    (edit - Gerry was quicker off the mark! UB1 - that's the board I was thinking of)
  2. #32
    Its a 5LPT board with ethernet connection? So you would use 5 BOB's too get full functionality??
    Just guessing, couldn't see a UB1 win the site ;)
    Edit,
    typing at same time ;)
    Makes sense now, I still prefer the CSMIO if not just for its "completeness" and rugged build.
  3. #33
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 20 Hours Ago Has been a member for 6-7 years. Has a total post count of 603. Received thanks 83 times, giving thanks to others 0 times. Referred 1 members to the community.
    "Full Functionality" would depend on the users needs. And there are 1 port, 2 port, and 3 port breakout boards. The UB1 uses 3 of the ports.
    http://www.cncroom.com/interface-cards/uc300eth-ub1
    You don't need the 5LPT board with the UB1, so you save a few bucks there.
    But it relies on flawed software, which is the main issue.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  4. #34
    Yes its one drawback and i have worked around it, I guess i could ask CSLABS if they have done anything on it as the linked stuff was a while back, doubtful though which is a pity IMHO.
  5. #35
    About as likely as retrofitting the dual-motor support from the IP-S into the IP-M, more's the pity.
