    HI
    a while ago I built a 3 axis system using a 10" x y table and a water cooled variable speed spindle. all the parts came from cnc4u except the x y table.
    it all works and I made a couple of projects but ive gone back to manual so its all up for grabs if anyone's interested.
    contact me if you are and I can list all the components
    cost a bl**dy fortune to build!
    cheers
    carl
    Could you pm me with the list and most essentially the price if you would please.
    sorry its taken so long to fill in the details
    control unit mounted and wired in a funky acrylic clear box, comes with all the leads.
    I have a licensed copy of mach3 not sure how to transfer the license tho
    cnc4u part codes
    CP0-10V breakout board
    UC300-USB
    CWD556 stepper controller 3
    36V 11A 400Watt PSU
    plus relay board to switch mains to control water pump, spindle & 1 spare. emergency stop no volt switch and z axis stop jack
    the xy table is made by NEAT, it is solid billet ali and weighs about 15kgs, it has 8" travel, the table is 10" square. The lead screws have a 2mm pitch. All the bearings are adjustable for backlash, at the opposite end to the stepper motor there is a dual ball bearing configuration that you pre load them against each other
    open to offers
    some pictures I hope
    carl
ID:	23444   Click image for larger version.
ID:	23443   Click image for larger version.
ID:	23442   Click image for larger version.
ID:	23445   Click image for larger version.
ID:	23446   Click image for larger version.
ID:	23447   Click image for larger version.
ID:	23448   Click image for larger version.
ID:	23449   Click image for larger version.
ID:	23450   Click image for larger version.
ID:	23452   Click image for larger version.
    Can I assume you have lost interest in selling this?
    this is the spindle mounted on a zero backlash ballscrew. It comes with a water pump and variable speed controller. all bought from cnc4u as a system so designed to work together. also a set or er20 ncollets, some unused.
    It has a Microsoft webcam with upgraded optics for zero location that works with mach3
    z axis limit switch.
    It all works fine and has hardly been used
    open to offers
ID:	23501   Click image for larger version.
ID:	23502   Click image for larger version.
ID:	23503   Click image for larger version.
ID:	23504   Click image for larger version.
    Quote Originally Posted by emlclcy View Post
    open to offers
    sold
    £200 for the x y table + controller
    Where about are you located? I am interested in the controller.
    Peter
    Basingstoke
    Ok PM sent
  1. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  2. Setting up "System 45" 3 axis unit by DIYCNC
    By StevenT in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 03:22 PM
  3. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 12:35 PM
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. Has Anybody used one of these G540 4-axis system
    By HS93 in forum Motor Drivers & Controllers
    Last Post: 05-03-2011, 11:11 PM
