Name:	MC Electrics 001.jpg
    Not a CNC problem, but hopeing someone can point me in the right direction.
    This is an electrical drawing of my C3-31 Hammer (Felder) combination machine.
    A few days ago it started tripping the MCB32A trip, which progressively got worse, on
    any of the motors (Saw, planner, spindle moulder) until it would not work at all.
    Suspected contactors, on enquiring with manufacturer was informed they only supply
    complete enclosures A1 item 2 on drawing at £500.
    So decided to purchase equivalent contactor and axillary contactor and fit.
    Result was it would work if I unplugged the motor. (Contactor would pull in)
    But if motors plunged in would sometimes work on Saw, but most of the time contactors "chattered"
    some times holding in and sometimes tripping MCB332A trip.
    The safety limits and stops are the same as a cnc machines so they should not be a problem.
    I have tried bypassing the overload protection - no effect.
    My suspicions are the braking circuit board, as I believe this works by injecting current back into
    the motor to produce a magnetic field to stoop the motor quickly. Has this broken?
    Causing some load to prevent the contactors working correctly?
    Any help greatly appreciated before I fork out the £500.
    Robert
    Break the connection of the braking circuit to the motor and test.
    Fault finding is a process of logical elimination, not speculation, the fact that multiple motors suffer the same issue suggests it isn't the motors but it can still be any other common component.
    Are the motors single or 3 phase?
    I'm sure it's clear on the schematic and DC injection braking is a 3-phase technique but you should post the schematic the right way up and at good resolution if you expect anyone to examine it closely, if you can't be bothered......... ;-)
    Regards,
    Nick
    It looks like it's 3 phase, I have a single phase version of this machine but it still has an electrical braking system.
    Does it trip when you start a motor or when you press a stop button ?
    It could be the rotary switch S7 (10), saw/moulder/planer, maybe it's losing a phase to the motors ?
Name:	MC Electrical Drawing 001 (2) (1024x745).jpg
    Drawing any better Nick?
    Translation from German:
    1 Home
    2 Switching Unit
    3 On Off Switch
    4 Overload Protection
    5 Contactor
    6 Auxiliary Contactor
    7 Braking Circuit
    8 Transformer
    9 Fuse
    10 Selector Switch
    11 Limit Switch
    12 Emergency Stop
    13 Emergency Stop
    14 Motor – Saw
    15 Motor – Spindle Moulder
    16 Motor – Planer
    17 Plug
    18 Limit Switch
    19 Limit Switch
    20 Terminal Strip
    Yes the motors are 3 phase run from a Transwave inverter.
    So disconnect wire R7 from the contactor to eliminate the Braking circuit?
    It trips or won't start when you press the start button. Contacts flash, chatter. But it does run on all three motors once it decides to hold the contacts in.
    But I don't think the contactor will last long if I keep using it like this.
    Thank you for your suggestions I will have another look at it tomorrow.
    Is the coil voltage correct on your replacement contactor ? it shows 230v AC on the drawing, have you checked the voltage at the coil with a meter while it's chattering ?
    Is the MCB332A which is tripping running the transwave and have you checked the output of the transwave as cack 3 phase into your machine will cause it to play up as various control bits are powered by single phases.
    Here is the replacement contactor details https://chaloncomponents.co.uk/produ...oltage=230v-ac
    I will check while chattering.
  1. Finding spindle suppliers in UK
    By freddi in forum Spindles & Drive Motors
    Last Post: 07-02-2017, 08:16 PM
  2. combination machine.
    By Popp Ann in forum 3D Printing Machines
    Last Post: 23-02-2016, 10:35 AM
  3. eBay: Cutler and Hammer (vice?) foot pedal
    By jamesgates1000 in forum Items On eBay UK
    Last Post: 20-10-2015, 07:33 AM
  4. Best CNC Software Combination
    By Ricardoco in forum CAD & CAM Software
    Last Post: 29-08-2011, 12:57 AM
  5. Edge Finding For Newbies
    By M250cnc in forum CAD & CAM Software
    Last Post: 01-03-2011, 10:55 AM
