03-12-2017 #11
I will find the Transwave manual and have a look, do you mean L2 and L3 on the drawing?
So using test meter on Hv setting I get 237v on a workshop socket outlet (just checking I'v got the correct range) then 160v over the low side of the transformer and 364v over the high
side. 160v seems too low?
The contacts made well some times and chatterd others. Going to look for manual for Transwave.
03-12-2017 #12
I was taught that 'rule' no1 when fault finding is, "check the supply"
A contactor needs more voltage to close than it does to retain but 160v is only about 70% of required, plus, as the motor applies load it is going to drop a lot further.
The other to watch is phase rotation, you don't want to be swapping phases around willy-nilly otherwise the motor direction could reverse.Last edited by EddyCurrent; 03-12-2017 at 02:59 PM.
03-12-2017 #13
You should test a supply in both no load conditions and with a load of a significant percentage of that with which you are having problems.
03-12-2017 #14
160V does seem low. It's not unknown for transformers to fail, but as Nick says, check what happens to the voltages when you try starting the motors. Test the high and low sides to see what happens.
Also test between the other legs when starting, to see if you any sag more.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-12-2017 #15
No desire to be pedantic about this but,
That's not what I meant about 'rule no1' , I meant if there was nothing there when you pressed "start". In other words, "check there is the required voltage at the machine".
The quality of the supply comes later after pressing "start" does it's job.Last edited by EddyCurrent; 03-12-2017 at 04:29 PM.
03-12-2017 #16
Sorry but I made a mistake when testing the voltage on the transformer, wrong connections.
Now get readings of 464v and 260v.
Also get 242v over the contactor.
What to check next?
03-12-2017 #17
What happens to the voltages while the motors are starting, and the contactor chattering?
04-12-2017 #18
From putting the meter over A1, A2 on the contactor and pressing the start button the voltage is not instant ie it climbs to 240v while it chatters,
same if you put it over any of the other contacts. When it pulls in it is 240v. So readings might be 50, 70, 130, 170 then 240v (all while chattering)
Is there a way of wiring out the braking board item 7 on the drawing and still making the machine work to eliminate it from being the problem?
I can disconnect wire 24 from the contactor to stop it breaking, but there are 5 other wires still connected.
Then I can happily spend the £500 knowing that that is the cause.
04-12-2017 #19
Testing is not proceeding in a logical manner.
Personally, I would install the original contactor first.
With the machine disconnected from supply, manually operate the contactor and confirm, using an ohmmeter, that all the contacts operate as expected.
Then I would remove the load, i.e. disconnect the selected motor, e.g. saw
Plug the machine in and press start and see if the contactor pulls in and holds
Now with a voltmeter I would test to see if we are getting 3 phases (full voltage) at the disconnected motor leads.
If not, I would start at the supply end and work my way through to find the reason.
If yes, then it suggests the wiring and contacts are okay, on no load at least.
If you then press stop, there should be DC across 2 of the motor wires for several seconds (it makes a loud humming noise under normal conditions)
If your machine works in a similar way to mine, if an e/stop button is pressed and you press 'start', then the braking system energises for several seconds just as during a normal stop.
This means that if the contactor, and it's contacts, are not working correctly it may be possible to initiate the brake during startup. This is the main reason
I would refit the original contactor and auxilliary as there may be some time delay involved here.
The drawing is one of the worst I've seen and it's not easy, for me anyway, to determine exactly what's going on, and I've used some complex drawing in the past.
I've attached a copy of the single phase version if it helps sort this out, (not studied it yet though)Last edited by EddyCurrent; 04-12-2017 at 10:55 PM.
04-12-2017 #20
If I'd been referring to your suggestions I'd have quoted you.
When looking for the source of a fault in a 3 phase electrical system where components such relays and actuators are commonly run from one phase with different components running from different phases then if you don't check what you have before applying any load at all then you can make things harder for yourself.
Just saying ;-)You think that's too expensive? You're not a Model Engineer are you? :D
Finding spindle suppliers in UK
By freddi in forum Spindles & Drive MotorsReplies: 1Last Post: 07-02-2017, 08:16 PM -
combination machine.
By Popp Ann in forum 3D Printing MachinesReplies: 14Last Post: 23-02-2016, 10:35 AM -
eBay: Cutler and Hammer (vice?) foot pedal
By jamesgates1000 in forum Items On eBay UKReplies: 0Last Post: 20-10-2015, 07:33 AM -
Best CNC Software Combination
By Ricardoco in forum CAD & CAM SoftwareReplies: 12Last Post: 29-08-2011, 12:57 AM -
Edge Finding For Newbies
By M250cnc in forum CAD & CAM SoftwareReplies: 14Last Post: 01-03-2011, 10:55 AM
