    Hi
    I would like to build a cnc machine that i can cut prototypes on that are around 500x400mm at there biggest size and will be made out of aluminium and also if possible i would like to might need to cut brass on it in the future.
    I would like to spend as little as possible hopefully well under 1000 if possible.
    Where do i go about starting?
    Thanks for the help
    Elliot
    Start by multiplying your budget by at least 2. I think that's a more reasonable start but even that is optimistic.
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 4 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,191. Received thanks 220 times, giving thanks to others 5 times.
    You could probably meet your budget if you only wanted light cutting in wood and plastic, but I would agree that (unless you have a private source of cheap hardware!) a machine to cut aluminium reliably would be 2K+ as a rough guide. It's a very approximate finger in the air, though, and while you might do better with very careful shopping around, a realistic budget from the start means that you are more likely to succeed.
    Ok thanks all I think I will need to wait a while before i can gather enough funds for a machine able to cut aluminium.
  1. DIY Machine to Build?
    By paulkane1 in forum Gantry/Router Machines & Building
    Last Post: 03-12-2012, 02:24 PM
  2. BUILD LOG: 1st Build, Second machine
    By m.marino in forum DIY Router Build Logs
    Last Post: 29-10-2012, 09:30 AM
  3. Replies: 2
    Last Post: 22-10-2011, 12:38 PM
  4. NEW MEMBER: Second machine build
    By tmsboss in forum New Member Introductions
    Last Post: 04-09-2010, 01:11 PM
  5. NEW MEMBER: Wish to make my future in CNC
    By AMBITIOUS in forum New Member Introductions
    Last Post: 03-09-2010, 10:48 PM
