Thread: concrete base
    Hi, just starting to get materials all rounded up for a new shed/workshop. the size is kind of weird as the only place i can have it is at the side of my house but it goes from 10ft wide all the way down to 4ft at the bottom end of the house and its 24ft long. what thickness should i make the concrete for the cnc machine? i am having the machine at the widest part so i was just going to make that area the thickest to save money.
    Quote Originally Posted by reefy86 View Post
    Are you making a brick or block shed, timber etc. but 100mm concrete with A142 mesh in it will be fine
    cheers clive, its going to be timber with osb3 boards :)
    Well then you would need about 1.5 cubic mts of concrete and two sheets of A142 mesh (merchant size)
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #5
    cheers clive
  7. Don't forget DPC and adequate insulation under the concrete, I wish my workshop floor had insulation under the concrete, it wasn't even though of 40 years ago :-(
  8. The Following User Says Thank You to magicniner For This Useful Post:
  9. #7
    Yes good point. The DPC is a must but the insulation is a nice addition even 50 mm would help.
  1. Improving my cheap DTI magnetic base
    By routercnc in forum Tool & Tooling Technology
    Last Post: 13-12-2016, 10:14 PM
  2. FOR SALE: Selling base of 3d models 90Gb
    By dariopp in forum Items For Sale
    Last Post: 08-06-2016, 09:32 PM
  3. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  4. New build in Kent, on Dexion base
    By Dan in forum General Discussion
    Last Post: 14-10-2010, 10:08 AM
  5. Base design for new router
    By cncgreg in forum Gantry/Router Machines & Building
    Last Post: 31-08-2010, 03:35 PM
