24-08-2009 #1
Hi all,
This is one for the experts, JohnS, Robin, etc. I suspect.
I need to fix the backlash on the cross- and top-slide on the lathe (the 85y old one)
It currently has 8tpi ACME (or something like that, square topped) threaded screws working onto a tapped cast-iron block which is the slide itself. In other words there is little opportunity to make another part. I'll get some pics/drawings done in due course but I'm guessing the wear is in the cast-iron block (nut) and not the screw as I can move the slide back and forth 2mm on the screw.
What are my options if I:
- want to retain the existing screws
- fit new metric trapezoidal screws, say TR10x2
- bore out the cast iron block (with my new boring head on the mill), assuming there is space and fit a bronze/delrin/whatever sleeve.
- mill out a section of the block and drop in a new 'nut'
I think the advantage of the second approach is I can trial different nuts and maybe get some form of anti-backlash approach in there...
ACME / Trapezoidal leadscrews
By ZeroCount in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 08-03-2020, 09:29 AM -
Belt Driving your leadscrews !
By Lee Roberts in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 05-02-2011, 09:14 AM -
Restoring a Kerry 1124 - Info and photos required
By Noname in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 27-12-2010, 02:45 PM -
Motors and leadscrews
By Tom in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 29-05-2009, 10:37 PM -
Ideas for fitting leadscrews
By irving2008 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 11-11-2008, 10:05 PM
