    HI,
    i need 8x of these 2 pieces for a friend. Any aluminum.Not super precise, surface finish could be sanding paper. But center holes must be at center and reamed 8mm. basically 30mm high, one is 70mm OD, other is 50mm OD.
    Long story short, i promised a friend i will do it for him on the CNC and then sand it on the lathe. I am busy, job is difficult and time consuming to do it on my machine. Could be done on a mill also, just center holes have to be reamed
    Will be more orders in very near future, by the 24x each time. This is just a test.
    Price is concern, concentricity is concern, finish and precision are not a big concern. 30.00 / +-0.05/ mm height.
    Come on people, help me here with this one! Give me a quick quote, do not invest much time thinking it, so i speak with my friend and later concretize it.
    It could be on a normal lathe if you find a way to do the same shape repeatedly
ID:	23336 Click image for larger version.
ID:	23337 Click image for larger version.
  2. The Following 2 Users Say Thank You to Boyan Silyavski For This Useful Post:
  1. BUILD LOG: Made of aluminum, Made for aluminum: Would love design critique!
    By gamingan in forum DIY Router Build Logs
    Last Post: 27-06-2017, 11:33 AM
  2. RFQ: Dublin, IRL Manual milling & lathe work required
    By 250rri in forum Projects, Jobs & Requests
    Last Post: 30-01-2014, 01:07 PM
  3. RFQ: Lathe Work Required, Small Batches,
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:13 PM
  4. what is required to cut threads on a cnc lathe/
    By swarf-boy in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 09-01-2014, 04:27 PM
  5. RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
    By Chas in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 09:28 AM
