Thread: Aluminium Extrusion Router Build
28-02-2018 #11
Hi Jazz, reading a few of the forum threads, I think most people use the 5mm pitch HTD pulleys with 15mm wide belts. Is there a certain number of teeth engaged with the pulley for best torque transfer, as I was looking at maybe the 20 tooth pulley, which is 26mm wide. The motor shaft with give me about 20mm so this should be ok I think. On the ballscrew shafts do you file flats onto the end to give the grub screws a better bite on it?
As for the ATC spindle my take on this is that I would need the ATC spindle, some form of linear or round tool holder, a compressor as I think that the tools are held in the spindle with pneumatics. How do the tool changes work, are they programmed into the G code that Mach 3 processes. I Have seen that each tool on a linear tool holder has a seperate set of coordinates and the tool height is reset each time and with the circular holders you need to rotate the holder to select tools, how is this programmed in. It all seems a bit complicated to me.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
By WandrinAndy in forum DIY Router Build LogsReplies: 54Last Post: 05-11-2012, 06:22 PM -
FOR SALE: Aluminium Extrusion
By vigen20 in forum Items For SaleReplies: 2Last Post: 24-07-2012, 11:01 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
Aluminium Extrusion suppliers?
By m_c in forum General DiscussionReplies: 3Last Post: 12-04-2011, 01:23 AM
