Thread: Milling Delrin - Advice needed
20-12-2017 #1
Hi All
I have a Sieg X2 mill converted to CNC and am just starting out on machining
- Spindle speed 0 -2000 rpm
- Not sure what feed rates I can go up to but it's a hobby machine
- Max endmill size 16MM
my main materials of choice will be Delrin and Acetal.
I just wanted advice on cutting speeds and feeds and also if I can get away with cutting dry. My research says that air blast is good for chip removal but I would prefer it if I can save the extra expense.
Also any advice on anything to do with machining the above is gratefully received
Thanks in advance :-)
Jools
20-12-2017 #2
Start with similar speeds to Alu and go from there. With 2k rpm you will be very limited. With 16mm Id start around 500mm / min for a 10mm deep 1mm wide cut. Clear chips with air, delrin isnt difficult from what I recall.
20-12-2017 #3
Yeah, pretty much what Chaz has said, I also have a 2000rpm spindle and usually cut delrin using cutters from 4mm up to 12 mm. I normally cut around 6mm depth @ 600mm/min. I never use coolant, or air blast for that matter, if needed I just follow the cutter around with the nozzle from the hoover
The Following User Says Thank You to needleworks For This Useful Post:
20-12-2017 #4
Air blast is better for getting chips out of slots and producing neater cuts, single flute end mills are fantastic in plastic where a deep slot is required.
27-12-2017 #5
Thanks guys, I'll give it a try at the speeds you've said and see what results I get.
Milling Plastazote LD33 closed cell Foam - Any milling advice?
By Zeeflyboy in forum General DiscussionReplies: 11Last Post: 20-11-2017, 12:46 PM -
Milling aluminium advice needed
By zxrjohn14 in forum General DiscussionReplies: 8Last Post: 08-11-2017, 01:18 PM -
Advice needed on everything
By chrisjames in forum General DiscussionReplies: 12Last Post: 11-11-2015, 10:40 PM -
VMC Tooling Advice Needed!
By cncJim in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 03-09-2014, 08:17 AM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 01:30 PM
