    "No I never used an earth, the plug has 4 connectors and one of them is left empty (No 4) "
    That sounds good and correct.
    Pin 1 Phase 1
    Pin 2 Phase 2
    Pin 3 Phase 3
    Pin 4 Not Connected
    The spindle needs checking out as cropwell explained.
    Regarding parameters I would change these.(when you get the new vfd)
    PD014 acceleration time, 1 second is too short in my view, 5 seconds sounds better especially in the early stages of setting up.
    PD015 decceleration time, same as above set to 5
    PD142 motor rated current, set this to current specified for the spindle, I looked at some and the correct figure seems to be 8.5
    PD143 motor poles, I don't know myself how many poles these spindles have but if people are using a value of 2 then it seems reasonable.
    PD001 set this to 0 if you are using the keypad controls.
    I'm wondering if you have reversed the motor several times without realising it from the front panel buttons, with ramp times of 1 second this may have caused some damage.
    As you say, a short at the spindle end would not do the vfd much good.
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. VFD Has defantly blown up now!
    By charlieuk in forum General Discussion
    Last Post: 30-08-2017, 02:45 PM
  3. 2.2KW 3HP Inverter help
    By adamh in forum Spindles & Drive Motors
    Last Post: 31-07-2015, 09:21 AM
  4. WANTED: Electrical Box for inverter
    By badgerman in forum Items Wanted
    Last Post: 28-09-2013, 11:08 PM
  5. Teco inverter
    By Ronaldo9 in forum Spindles & Drive Motors
    Last Post: 20-01-2013, 01:42 PM
