    Hi Guys
    I do not know if the standard mach3 fusion post will work for the 8 station ATC Denford Triac or if it will need editing, and if so how.
    Many thanks
    Steve
    Lives in East Lothian, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Try running it and see.
    Although a basic Fanuc 0M post processor may be more suitable, and there are a couple Denford post processors in the autodesk library at http://cam.autodesk.com/posts/
    Thank you m_c
    Happy Christmas to you.. I will try when I get that far I am hopeless with fusion never got any gcode from it yet!!
    I have just been trying and again it comes up with the msg in the image.
Name:	fusion issue nuber !!!.png
    That's normally because you're using an unsuitable tool type (i.e. a drill, and not an endmill), a toll with too big a diameter, and/or the toolpath settings aren't letting it run at tight enough of an arc to fit in the hole.
    You might want to have a look at this video for various ways to bore a hole - https://www.youtube.com/watch?v=nKbEzSleF14
    (NYCNC vids are usually pretty good, and their Fusion Friday videos have a good few tips in them)
    Morning m_c
    Tar very much for the help. Yes I like the videos that mycnc John does, learnt good bits from him. In fusion I was just trying to drill 2 3.5mm holes I selected a 3.5mm twist drill. I will have to go back over fusion videos again beacuse no matter how simple the thing I try to do fusion says no!
    Thanks again
    If you're trying to drill the holes, then you need to use the drilling option.
    Bore is essentially a variation of a 2D pocket, and uses milling cutters to helix/spiral into holes.
    Thanks I thought bore was for boring holes! Really appreciate the help.
    Quote Originally Posted by suesi34e View Post
    As mc says it is for making holes but they are interpolated holes. So you can use a 6 mm end mill to bore a 6.8 mm hole ready for an M8 tap etc
    Don't need a 6.8 mm drill etc
    Thank you mate appreciate the help. All the best for 2018
  1. FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
    By Piero franchi in forum Items For Sale
    Last Post: 14-02-2017, 04:47 PM
  2. FOR SALE: Denford Triac + Denford Orac + other stuff
    By Clive S in forum Items For Sale
    Last Post: 06-02-2017, 11:47 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. eBay: Denford Triac CNC milling machine mill mach3
    By Fivetide in forum Items On eBay UK
    Last Post: 19-11-2012, 01:46 PM
