Thread: Mach3 Edge Finder
08-03-2018 #11
Dfox, I have macros for probing X, Y and Z which are implemented on my Mill controller. I use a dedicated setter for height, a spring-loaded button that the tool touches. For X and Y I have an isolated tip probe of known diameter (~10mm) so it can pick up the edges of a metal workpiece. You enter the probe diameter in the "Edge Finder Diameter" DRO in the offsets screen. Happy to let you have copies of these (they are mainly based on ones off the Mach3 support forum anyway).
Probing edges with a tool as shown in that video only works if you can isolate the work, since the tool is inevitably grounded through the machine. I am working on a probing system that detects contact between a tool and the work where both are grounded, at the moment on my lathe, but later I'd like to retrofit to the mill.
Any ideas or thoughts on making a edge finder come touch off tool
By suesi34e in forum Electronic Project BuildingReplies: 26Last Post: 01-01-2020, 06:28 AM -
Where to buy from sound and led 1/2" shank or ER25 edge finder, ?
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 9Last Post: 28-04-2016, 12:01 AM -
Wiring a Corner finder and height control
By D-man in forum Probing, Digitizing & ScaningReplies: 38Last Post: 02-11-2014, 03:41 PM -
1/4" / 6mm edge finder?
By jcb121 in forum Marketplace DiscussionReplies: 0Last Post: 18-03-2013, 02:58 PM -
Electronic edge finder: how do they work?
By irving2008 in forum Probing, Digitizing & ScaningReplies: 14Last Post: 29-08-2009, 10:25 PM
