    Anyone knows from where to buy insert/ or not/ bit for making 30-40mm grooves on MDF doors, main thing is i have 3.2kw spindle so limited to 1/2" shank . Any help will be appreciated
    Hi Boyan
    Nice to see you back on the forum again, you could try Wealden Tools, i used them when i was getting tooling together when i made my windows.
    https://www.wealdentool.com/acatalog...Cutters_1.html
    Regards
    Mike
  3. The Following User Says Thank You to mekanik For This Useful Post:
    Thanks. At the end i went with CMT 870.504.11
    I assume whatever i do will finish with round outside corners. Hope that looks good. Chose 35mm width , more or less as the doors i have at home. The only doubt i have is if this could plunge and what speeds and feeds...
    https://www.ebmia.pl/caches/images/p...0_504_11_1.jpg
    A very nice short video how to program the custom shape of the profile cutter in Vectric V carve or Aspire. It took less than a minute.
    So now i can preview the cut
ID:	25899 Click image for larger version.
Name:	mdf door profiling 2.bmp
    Still not quite sure about the speeds and feeds with this 35mm bit, depth is 9.5mm. Will try it tomorrow at 16k rpm / on the tool it says it can/ 5000mm/min, 1.5mm depth of cut. It will take 7 cuts to finish to final depth of 9.5mm.
    I believe i can go 2mm deep at 7000mm/min probably, but will start easier on the spindle. The initial speed will be like 13 min to finish one side of the door. Seems pretty slow to me.
    Anyone has experience with ogee bits in MDF?
  1. eBay: Haimer 3d taster 20mm shank
    By camhguh in forum Items On eBay UK
    Last Post: 05-02-2018, 04:44 PM
  2. Threading V grooving tool needed
    By howser37 in forum Tool & Tooling Technology
    Last Post: 31-01-2017, 03:22 PM
  3. Kitchen doors
    By D-man in forum Woodwork Discussion
    Last Post: 02-10-2016, 05:08 PM
  4. Leitz Router Bit, Odd Shank Size?
    By gazza in forum Tool & Tooling Technology
    Last Post: 27-02-2011, 03:26 PM
  5. What size (3mm shank) ball endmill should buy?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 28-07-2009, 12:07 AM
