Thread: Hi from Lincoln
    Hello All
    I'm Fabian from Lincoln in Lincolnshire (UK) and I'm interested in constructing an Axidraw writing clone. I bought some items from Banggood (China), but I'm still looking for suppliers here in the UK.
    I have a few questions about wiring and setting up the Arduino as well as how to join two ends of a GT2 Timing Belt so I can get it to the correct size.
    I didn't want to start using the forum with a warning about not posting in the right section so I've used this introduction to get an idea of where to ask my questions.
    Thanks a lot.
    Fabian.
    Hi Fabian and welcome to the forum. Just post where you feel is the correct place or start a build log to keep all the questions in one place, regarding the timing belt you can buy them any length or ever made to measure.
    Thanks Clive
    Is there a supplier of Timing belts in the UK
    Thanks a lot.
    Fabian.
    Quote Originally Posted by Fabian View Post
    Thanks Clive
    Thanks a lot.
    Fabian.
    A search engine is your friend.
    I use City Seals and Bearings in Sheffield but most cities with any local industry will have a bearing and seal supplier, or 3
    Thanks Clive
    Thanks a lot.
    Fabian.
    As Eddy has pointed out google is your friend. http://www.beltingonline.com/rubber-timing-belts-40/
    https://www.accu.co.uk/en/815-htd-ty...ts-and-pulleys
  1. NEW MEMBER: Hello from Lincoln UK (Converting Warco WM14, need to learn G-Code or CAD CAM)
    By Jools in forum New Member Introductions
    Last Post: 21-02-2018, 06:33 PM
  2. NEW MEMBER: Hi from Lincoln
    By centurian in forum New Member Introductions
    Last Post: 04-02-2015, 02:14 PM
  3. NEW MEMBER: New member/machinist from Lincoln, East Midlands
    By Franco in forum New Member Introductions
    Last Post: 31-07-2011, 11:03 PM
  4. NEW MEMBER: "L" plates attached, from Lincoln
    By Jayman in forum New Member Introductions
    Last Post: 02-10-2010, 01:26 PM
  5. NEW MEMBER: Greetings from Lincoln UK
    By jesse in forum New Member Introductions
    Last Post: 30-09-2010, 03:50 PM
