11-01-2018 #11
Yes Nick, I did suggest that software was fit for the bin ! I wouldn't use it as it is unfamiliar to me. If I were to spend money, it would be on a Mach3 licence OR if I wanted to learn something new then I would try LinuxCNC.
Cheers,
Rob
And may I be the first to wish you all a Happy Easter!
11-01-2018 #12
11-01-2018 #13
So was there a registration code included in the package ?
12-01-2018 #14
12-01-2018 #15
13-01-2018 #16
very quick question, after installing the software that was supplied by the seller (USB CNC controller) and using the USB to LPT cable I was able to move the motors abet very slowly however I weren't too happy with the software and cable (it does seem to be a cheap clone and pirated software especially when I have an activation code that does not work and so stuck with a trial version) also it did not allow Mach3 to work either or register as an add-on (I may have not set this up right though...)
So to simplify things for me I am looking at using the old fashioned way of parallel port to parallel port connection between the pc and cnc machine for now then later invest in a UC100 and purchase the legit software.
My question is this - both my pc (main board) and cnc machine are 25pin female connections, do I simply buy a 25pin male to male cable? or would I need a different setup as I found a parallel port 6040 on ebay and the cable supplied was a male to female connector?
It seemed so simple but when I researched this on the internet it seems everyone just forgets about this part and talk about setting up the pins or jumping straight from packaging to milling...
13-01-2018 #17
Buy a parallel port cable which fits your socket configuration, unless it happens to be cheaper to buy male to female and a gender changer, sometimes it is, sometimes it isn't.
Planet CNC USB Controllers have never worked with Mach3, according to Planet CNC Support -
http://forum.planet-cnc.com/viewtopic.php?f=6&t=2246
I can't see it being different with clone hardware, unless the manufacturer has written a working Plug-In Mach 3 was only ever going to work with your current hardware using a parallel cable, fingers crossed ;-)
13-01-2018 #18My question is this - both my pc (main board) and cnc machine are 25pin female connections, do I simply buy a 25pin male to male cable? or would I need a different setup as I found a parallel port 6040 on ebay and the cable supplied was a male to female connector?..Clive
13-01-2018 #19
If it's a serial port on the PC it will have visible pins (male), parallel ports on the PC have holes (female) ;-)
The Following User Says Thank You to magicniner For This Useful Post:
15-01-2018 #20
Success I have finally made my PC talk to my CNC machine, I have brought a male to male LPT 25pin cable and the response is smooth.
I will eventually invest in the USB converter devices that you mentioned but that's for another day when I have some spare cash.
I've done a Youtube video as well for you all to laugh at as not done a Youtube video in years, showing my inexperience on the topic. https://youtu.be/KoGgAq6H0Ww
now to buy mach3 and trial Vcarve.
cheers all for your help I will pick your brains on other subjects sooner probably than later.
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
5 axis setup
By Blackrat in forum General DiscussionReplies: 0Last Post: 12-09-2015, 06:56 PM -
Z-Axis setup
By Yaser in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 18-12-2014, 10:26 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
FOR SALE: 4th axis setup
By johngoodrich in forum Items For SaleReplies: 4Last Post: 13-06-2012, 06:17 PM
