Thread: Stock on facing
Is the top of your part Z zero?
It's kind of an industrial standard thing that's worth working with until you know better ;-)You think that's too expensive? You're not a Model Engineer are you? :D
20-01-2018 #2
20-01-2018 #4
Well it's the top of the stock but in the corner. So it's still the top it's just I prefer my zero position in the corner.
Also the facing operating is removing the correct amount off the stock it looks like the pocket operation after isn't taking that into account.
Sent from my SM-N910F using Tapatalk
20-01-2018 #5
20-01-2018 #6
i know its not but ot shoudl take into account the stock is thicker than the part and the take .45mm off the pocket if the stock has been faced.
the first operating is a face to remove .45 and the next is a hole pocket and the operating after is to pocket 2mm not 2.45mm. On the simulation the z moves down to 2.45mm
http://a360.co/2mUUlN4Last edited by dfox1787; 20-01-2018 at 12:44 PM.
20-01-2018 #7
You are mixing things up and trying to make the CAM work the way you think it should.
It's obvious that you are taking .45 off your stock but referencing your pocket depth as it would be from Top of Stock but your CAM is taking it from the actual Top of Part.
Setting Top of Stock as Top of Part is the source of your issues, you'll have to work out how to juggle the numbers in CAM to deal with that, a spreadsheet would help in keeping track of the differences required ;-)Last edited by magicniner; 20-01-2018 at 01:00 PM.
roundbar stock
By dfox1787 in forum VectricReplies: 4Last Post: 10-01-2018, 02:51 PM -
where to buy stock aluminium
By dfox1787 in forum Marketplace DiscussionReplies: 9Last Post: 27-12-2017, 11:27 PM -
Metal Stock Purchasing UK
By paul_m in forum Metalwork DiscussionReplies: 7Last Post: 25-05-2015, 04:42 PM -
RFQ: RFQ: Keyslot milling in alu round stock.
By Saracen in forum Projects, Jobs & RequestsReplies: 2Last Post: 05-09-2013, 09:42 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM
