Thread: Stock on facing
    Hi
    hope someone can explain this to me.
    i have a part that is 6mm in height. My stock is 6.45. i use a facing tool path that removes .45 making the stock 6mm in height.
    I have a pocket that is only meant to remove 2mm but when i run the simulation its removing 2.45mm
    Ive tried selecting the top height from the top of the model in the tool path settings but it still removes 2.45mm.
    can anyone help?
    Quote Originally Posted by dfox1787 View Post
    Hi
    can anyone help?
    If I were doing that part, I would make the last setting on the heights tab as "Bottom Height" From > Model Top, and the "Offset" as negative 2mm Not saying that's the correct way to do it, just how I would do it.
    Is the top of your part Z zero?
    It's kind of an industrial standard thing that's worth working with until you know better ;-)
    Yes the bottom left corner is set to zero. I can send you the file to have a look.
    Sent from my SM-N910F using Tapatalk
    This is confusing as magicniner asked "is the top of your part zero" and you said "yes" and then said left bottom corner is set to zero!!
    The normal way to start is to use the top of the part as Zero and any movement below that becomes -ve
    Well it's the top of the stock but in the corner. So it's still the top it's just I prefer my zero position in the corner.
    Also the facing operating is removing the correct amount off the stock it looks like the pocket operation after isn't taking that into account.
  1. roundbar stock
    By dfox1787 in forum Vectric
    Last Post: 10-01-2018, 02:51 PM
  2. where to buy stock aluminium
    By dfox1787 in forum Marketplace Discussion
    Last Post: 27-12-2017, 11:27 PM
  3. Metal Stock Purchasing UK
    By paul_m in forum Metalwork Discussion
    Last Post: 25-05-2015, 04:42 PM
  4. RFQ: RFQ: Keyslot milling in alu round stock.
    By Saracen in forum Projects, Jobs & Requests
    Last Post: 05-09-2013, 09:42 AM
  5. Method for holding Stock
    By Chaz in forum Machine Discussion
    Last Post: 24-06-2013, 11:41 AM
