Thread: Stock on facing
Hi
hope someone can explain this to me.
i have a part that is 6mm in height. My stock is 6.45. i use a facing tool path that removes .45 making the stock 6mm in height.
I have a pocket that is only meant to remove 2mm but when i run the simulation its removing 2.45mm
Ive tried selecting the top height from the top of the model in the tool path settings but it still removes 2.45mm.
can anyone help?
19-01-2018 #2
19-01-2018 #3
Is the top of your part Z zero?
It's kind of an industrial standard thing that's worth working with until you know better ;-)You think that's too expensive? You're not a Model Engineer are you? :D
20-01-2018 #4
20-01-2018 #5
20-01-2018 #6
Well it's the top of the stock but in the corner. So it's still the top it's just I prefer my zero position in the corner.
Also the facing operating is removing the correct amount off the stock it looks like the pocket operation after isn't taking that into account.
Sent from my SM-N910F using Tapatalk
roundbar stock
By dfox1787 in forum VectricReplies: 4Last Post: 10-01-2018, 02:51 PM -
where to buy stock aluminium
By dfox1787 in forum Marketplace DiscussionReplies: 9Last Post: 27-12-2017, 11:27 PM -
Metal Stock Purchasing UK
By paul_m in forum Metalwork DiscussionReplies: 7Last Post: 25-05-2015, 04:42 PM -
RFQ: RFQ: Keyslot milling in alu round stock.
By Saracen in forum Projects, Jobs & RequestsReplies: 2Last Post: 05-09-2013, 09:42 AM -
Method for holding Stock
By Chaz in forum Machine DiscussionReplies: 4Last Post: 24-06-2013, 11:41 AM
