    Hello everyone, this is my first CNC build. Currently I'm in the planning process and I would like to share with all of you my ideas about the design and hopefully receive the feedback of other experienced members of this great forum.
    The frame will be comprised of aluminum tubing of 70mm x 45mm x 3mm (wall thickness) and 5 mm steel plates to join the different pieces. Currently some of the fixing holes for screws/nuts are not included. The dimensions of the different pieces are as follows:
    Front and rear tubes = 600 mm
    Left and right tubes = 540 mm
    Fixing corner plates = 100 mm x 100 mm / 45 mm x 45 mm
    Fixing center plates = 160 mm x 70 mm x 80 mm x 45 mm
    My idea is to machine soft materials as well as aluminum.
    Thanks in advance for any suggestions you may have.
ID:	28947   Click image for larger version.
ID:	28948   Click image for larger version.
ID:	28949   Click image for larger version.
ID:	28950   Click image for larger version.
ID:	28951   Click image for larger version.
ID:	28952   Click image for larger version.
ID:	28953   Click image for larger version.
ID:	28954   Click image for larger version.
ID:	28955   Click image for larger version.
    Hello again. Some updates. In this time adding linear rails (HIWIN?) 20mm and ballscrews 1204. (Diameter 12mm / Lead 4mm).
    Please feel free to ask anything you want about this.
ID:	28960Click image for larger version.
ID:	28961Click image for larger version.
    Best regards and have a nice week.
    Quote Originally Posted by yosmany View Post
    Looks ok so far. 1204 ball screws might be a bit slow on pitch. Also not as stiff as 16xx when pushing away from the fixed bearing.
  4. The Following User Says Thank You to routercnc For This Useful Post:
  5. #4
    Thank you very much for your reply.
  1. Complete soundproofing setup for 6040 sized CNC
    By suspension in forum Classified Ads, Buy, Sell & Swap
    Last Post: 24-03-2018, 05:36 PM
  2. BUILD LOG: Desktop sized CNC
    By TadasM in forum DIY Router Build Logs
    Last Post: 05-02-2017, 02:47 PM
  3. Looking for a dremel sized cnc router
    By isdngirl in forum Marketplace Discussion
    Last Post: 29-04-2014, 12:01 AM
  4. Imperial sized lead screws?
    By fentiger in forum Lead Screws, Nuts & Supports
    Last Post: 14-06-2013, 10:16 PM
  5. RFQ: Custom sized aluminium enclosure required
    By benbenrf in forum Projects, Jobs & Requests
    Last Post: 26-10-2009, 04:16 PM
