  1. In a bored moment (well a bored day) I thought I'd add a spindle brake to my MD500 drill/mill
    ...bloody marvellous - wished I done it years ago!
Name:	Spindle Brake 1.jpg
ID:	826   Click image for larger version.
Name:	Spindle Brake 2.jpg
ID:	827   Click image for larger version.
Name:	Spindle Brake 3.jpg
ID:	828   Click image for larger version.
Name:	Spindle Brake 4.jpg
    Looks like a winner Bill, now for my "still learning" question...
    Why do you need a brake ?
    .Me
  3. Quote Originally Posted by Lee Roberts View Post
    I was born with only two arms ;)
    It just means I don't need to use two spanners to tighten/loosen the ER32 chuck (especially useful with a 13-12 collect and a 1/2" drill 'cos the *ing thing keeps dropping down onto the work before I can get the collet closed down onto the bit)
  4. Quote Originally Posted by BillTodd View Post
    Excellent idea Bill.. I was struggling today to hold the spindle still, the chuck in the quill and do the drawbar up...
    Yours looks suspiciously like my MD30...
  5. Quote Originally Posted by irving2008 View Post
    It's a NuTool MD500-30, one of a huge number of 'RongFu 30' clones, which usually have '30' in the name somewhere to distinguish them from the much smaller '25' and 'square post 40' models
  6. Here's the varispeed idea I'm playing with ATM
    Basically it's mounting a Piaggio Scooter CVT on top off the existing pulleys (believe it or not they will fit inside the belt cover).
    I'm not sure exactly what range the CVT will give (calculating the ratios it's not as simple as measuring the min/max diameters) but it should be at least a 3:1 range.
Name:	mill-drill with CVT.jpg
  7. Well the CVT sort of works:
    the back of fenner final drive belt just catches the post causing a horrible buzzing. I'll need to source a slightly longer CVT belt, so that the intermediate pulley arm can swivel out slightly to allow the belt to clear the post
    [ame="http://www.youtube.com/watch?v=s5iAb3IL1Hc"]YouTube - RF30 CVT1[/ame]
ID:	870   Click image for larger version.
ID:	871   Click image for larger version.
ID:	872   Click image for larger version.
Name:	Fits in casing.jpg
ID:	873   Click image for larger version.
Name:	Spring loaded pulley.jpg
  8. Knocked up a new shaft for the intermediate pulley .
Name:	Intermediate shaft.jpg
  9. Finished! New belt arrived today - no more buzzing noise.
    Changing the front belt I can get speeds from 175 to 1860 in four over lapping ranges.
    Pulley Vmin - Vmax
    1 == 548 - 1860
    2 === 393 - 1409
    3 ==== 290 - 977
    4 ===== 175 - 633
Name:	LH side view.jpg
ID:	910   Click image for larger version.
Name:	Hi speed1.jpg
ID:	911   Click image for larger version.
Name:	Low speed1.jpg
ID:	912   Click image for larger version.
Name:	Fits in casing1.jpg
    So basically if you only ran 1 and 4 you would have the whole range ?
    What about doing just a two speed pulley using a 6 rib Poly vee belt drive and that way you could get the smaller pulley on the intermediate shaft a tad smaller without loosing wrap round as Poly vees' don't suffer from this like V belts and you could probably get to less than 100 rpm.
    Mind you if you are on CNC then it's a different ball game to the manual owner who needs low revs for large cutters and boring.
    John S -
  1. FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
    Last Post: 04-08-2013, 10:30 PM
  2. NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
    By AGB in forum New Member Introductions
    Last Post: 06-02-2013, 03:16 AM
  3. WANTED: Small CNC Drill/Mill
    By Mad Professor in forum Items Wanted
    Last Post: 03-09-2010, 01:28 PM
  4. Is it possible to modify a drill to be an end mill?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 29-04-2010, 02:51 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
