Thread: Uc300
02-02-2018 #1Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
Considering one of these for a lathe. I need 3 axis control, Z, X and Turret.
https://www.cnc4you.co.uk/UC300
Does this allow me the following:-
0-10V for Spindle or do I need to use my RS485 via USB? Id like to use their software and ditch Mach at some point.
Z, X and Turret stepper control.
Usual limits
Threading? Can this be done with an encoder that provides an Index pulse?
Do I need to buy anything else for this board? PSU?
It's not listed on the features, but this tells you what you need to know about threading and encoders - http://forum.cncdrive.com/viewtopic.php?f=19&t=299
The Following User Says Thank You to m_c For This Useful Post:
02-02-2018 #3
I would highly recommend the ethernet version, along with the UB1 breakout board.
http://www.cncroom.com/interface-cards/uc300eth-ub1
Note that there is no "lathe" mode in UCCNC at this time.
For lathe use, I think the Centroid acorn may be the best hobby control right now.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
02-02-2018 #4Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
02-02-2018 #5Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
Gerry, does this board - https://www.cnc4you.co.uk/UC300 - need a Breakout board of sorts or is this all that is needed?
02-02-2018 #6
Yes, both the USB and ethernet UC300's need a breakout board. (or multiple breakout boards).
The ethernet UC300 is more powerful and faster than the USB version, and the cost is about the same.
Imo, UCCNC is much better than Mach3. Better trajectory planner, and mostly bug free. If you find a bug, they'll usually have it fixed in a few days.
It's missing some features that Mach3 has, but for most people, but they are features that most people don't use anyway.Gerry
03-02-2018 #7
Chaz if your converting lathe you want Centroid Acorn. Nothing else can touch it. Watch this.
http://www.centroidcnc.com/centroid_...ontroller.html
03-02-2018 #8Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
Thanks, spotted it too, looks good.
Will it allow me to use a rotary turret with some form of macro like Mach?
03-02-2018 #9
03-02-2018 #10
I've been able to do all that for the past 5 years on my lathe (and not have limited IO)... ;-)
The real benefit of Acorn would be the conversational programming, but you have to consider how often you'd use it.
It is something I thought I'd really miss when I dumped Mach3, but in the past 5 years, there's only be once where I've really missed having the ability. However nearly everything I do is repeat production, so I design it once on a computer, generate the G-code, and copy it to the lathe where it remains with just an occasional tweak if needed. If I was doing more one-off/repair parts on the CNC lathe, I'd of probably pulled my hair out by now.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
UC300 Ethernet
By noyloj in forum CNCdrive (UC100, UC300ETH)Replies: 12Last Post: 02-01-2017, 10:21 PM -
Uc300 motion controller problems
By Hellfire in forum CNCdrive (UCCNC)Replies: 2Last Post: 07-11-2016, 07:21 PM -
Grounding help, UCCNC, UC300 and connection loss
By gabi68 in forum CNCdrive (UC100, UC300ETH)Replies: 6Last Post: 14-10-2015, 07:42 PM -
FOR SALE: uc300 motion control board slighly used
By dazza in forum Items For SaleReplies: 1Last Post: 09-09-2015, 12:25 PM -
By dazza in forum Items For SaleReplies: 0Last Post: 09-09-2015, 12:23 PM
