Thread: Thread milling
    I am experimenting with thread milling. My current test is M30. Using Estlcam V11 Thread milling wizard with a home grown single point tool.
    I have a few 4 flute woodruff style cutters that I can grind to 60 deg quite conveniently. But I cannot quite mentally calculate if this multi point approach will overcut the thread width on a down spiral toolpath. Since the cutter will not have a pitch on the teeth
    Hope an expert out there will be able to comment.
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,231. Received thanks 245 times, giving thanks to others 6 times.
    A multi tooth cutter in that case is no different from a single point cutter, except you have X teeth cutting in a single line, instead of a single tooth cutting a single line.
    You're amount of overcut, is just the same a single point cutter, in that it depends on the relative diameters. A big diameter cutter in a relatively small hole is going to overcut more, than a small diameter cutter in a relatively big hole, regardless of the number of teeth.
  1. Milling Plastazote LD33 closed cell Foam - Any milling advice?
    By Zeeflyboy in forum General Discussion
    Last Post: 11-01-2019, 02:58 PM
  2. Square/Acme/Trapezoidal thread milling?
    By m_c in forum Tool & Tooling Technology
    Last Post: 22-04-2017, 12:07 PM
  3. Thread sealer.
    By Wal in forum General Discussion
    Last Post: 24-08-2016, 01:07 PM
  4. Thread milling shallow bind hole
    By suesi34e in forum Metalwork Discussion
    Last Post: 15-12-2015, 01:03 PM
  5. Not Just another Boxford tcl 125 thread....
    By cooliced in forum Boxford Lathes
    Last Post: 18-08-2011, 10:15 PM
