    Is there a cool way of quieting down the metal can type shop vac,s? Without causing them to overheat.
    I had excellent results by putting the whole thing in an 18mm plywood box, lined with foam on inside. Hinged top with clips and a foam draught excluder seal. A 4" hole at the back is lined up with the exhaust port. The only noise is the airflow.
    Box has 4 castors for wheeling it around.
    The airflow noise was actually massively reduced in volume when I added the cyclone dust catcher (from screwfix).
    My shop vac was stupid loud before, its barely noticeable now.
    As to overheating- it could easily be an issue. I've only run it for an hour at a time, usually only a few minutes and it's not been a problem.
    For running extended periods, I could run it with box lid open and still get ~80% sound reduction.
    I couldn't live without it now- hated that noise!
    As to overheating
  3. The Following User Says Thank You to PaisleyPCdoctor For This Useful Post:
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 15 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I thought that most of the cooling came from that high volume of air going through it? Comes out of mine fairly warm, anyway. Not a lot of scope for cooling apart from that, especially in a plastic-cased model like mine (£35 from Wickes).
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #4
    That is an excellent point. Thanks.
  1. wheres best to shop for parts
    By Palletlad in forum Marketplace Discussion
    Last Post: 28-03-2018, 12:31 PM
  2. NEW MEMBER: Machine shop
    By JAMAK in forum New Member Introductions
    Last Post: 24-06-2015, 09:49 PM
  3. NEW MEMBER: Newbie from Design Shop
    By designshop in forum New Member Introductions
    Last Post: 23-01-2015, 10:03 AM
  4. Carbide End Mills now available from shop-apt.co.uk
    By APT in forum Manufacturer News
    Last Post: 07-03-2012, 10:23 PM
  5. CNC shop to mill parts - does anyone know of any?
    By lateAtNight in forum General Discussion
    Last Post: 17-12-2010, 02:11 AM
