Hello
I'm a complete newbie and am about to embark on a build of a C-Beam Plate Maker. Still awaiting delivery of the mechanical bits and pieces so have been using the titmice reading and reading posts and build logs. I am wondering about the motion controller and the Centroid Acorn CNC12 system caught my eye. I've read through what threads I could find on the subject but haven't as yet found anyone in the UK who has tried it. As far as I can see, it's only available from Centroid in the U.S. or from Makersupplies in Denmark. The U.S. price (at £250) is £100 less than the Denmark price. Is the difference accounted for by import charges and VAT? By my reckoning the total from the U.S. should work out at around £310. Am I missing something?
Any advice will be very welcome. Thanks in anticipation.
Jim from Cheltenham, GLOS.
23-02-2018 #2
Hi Jim,
I've got Centroid controller and it's nice piece of kit thou not quite router friendly just yet because of how it's mostly geared towards Mills/Lathe's regards tool changing and few other bits. However centroid are working on router specific items which will hopefully be in the next software update.
Can I ask what you plan to cut with C-beam plate maker.? . . . . It's not exactly the best of designs and lacks in lots of areas which will quickly show over time or if plan to do any proper cutting.
If you'd come on here and asked about the design you would have got numerous folks, me included, all telling you same thing.? DONT BUY IT.!
The design is weak and flawed in key areas.
Don't be fooled when you see videos etc cutting aluminium because while it may manage to survive a video or two scratching it's way thru aluminium it certainly won't last very long in real world. Those plastic rollers will be dead in short order of time from chips and will most certainly start jamming up causeing stalls etc if not constantly cleaning chips away from profile and rollers.
In all honesty the Centroid would be wasted on machine like this. Cheap BOB and Mach3 or Linux CNC are more than good enough for this machine.
My advise would be if can return the parts do so and look to build better machine. Might cost little more but you will have good machine that can do all you want and probably more.
With this design your just buying weak ticking time bomb that you will quickly find lacking.!
Sorry to be Doom & Gloom but we see this all too often.!
23-02-2018 #3
Dean has been very restrained in his comments about this machine! My own first CNC router was built from MDF to a widely-available design, and I was attracted to that by plenty of video clips and so on showing how well it worked. And it did work, and turned out some useful work. But I spent more time tweaking and adjusting and repairing and strengthening it than I actually did using it! If you go ahead with the C-Beam machine, regard it as a taster and not a real machine, and one that you will grow out of very quickly.
On the subject of controllers, you are looking at something which is rather OTT for the machine. Cheaper and functionally better solutions for a machine like this (and that would be still be very usable on a Mk2 machine when you build it!) are available. Undoubtedly the cheapest but very workable solution is to use LinuxCNC with a simple break-out board. You could pick up a suitable second-hand PC from eBay for around £50, find a cheap monitor/keyboard, breakout board from eBay for a tenner, and you're ready to go. You are going to have to buy stepper drivers and so on anyway, so I'm not including those.
That needs a machine with a parallel printer port. If you want to avoid using one of these (and you are unlikely to buy a new PC these days that has one) then the next-best is something like a UC100 controller which connects to the PC using USB. That will run with Mach3, or can use UCCNC software which is cheaper and is becoming fairly well-regarded. Add in a breakout board again, and assuming that you have a spare PC available then you have a decent motion control solution for around half the cost of the Centroid and which will transfer to a Mk2 router very nicely.
Just some thoughts. There are plenty of build logs on this site which show the range of machines that members have built, almost any of which will beat the C-Beam hands down! And there's plenty of help and advice available once you get started.
23-02-2018 #4
23-02-2018 #5
Well, that's blown me right out of the water. If I go for the UCCNC option what are your recommendations for the hardware? I mainly work in wood and had been thinking about inlays, relief carving, photo carving etc. with maybe some small engraving on thin brass and/or aluminium. I cannot see that I will ever want to do any serious milling. I have made a few of Clayton Boyer's wooden clocks using my Diamond fretsaw and I would like to have a crack at using a CNC router to cut the cogs etc. To repeat, most of my work will be with various types of wood. So, any thoughts or advice will be most welcome before I commit myself. Thanks to you guys who have replied so far.
24-02-2018 #6
It's a difficult one to answer, as it's all about compromise and getting the balance between cost, complexity, time to build, materials to cut, etc. However, you are not being over-ambitious in your requirements - too many people start out with "Oh, I need to cut a little bit of aluminium as well!", not realising that it's not the amount of aluminium that matters, it's cutting it at all! However, you say engraving which is a very different matter.
The build-it-yourself answer in this size range is probably an aluminium extrusion-based machine. Very popular and seem to give very good results, depending on the effort and care you put into designing (with plenty of examples and advice from this site) and building. Lots of decisions about drive mechanisms - the high-end solution would use ballscrews and Hiwin-style profile rails. Alternatively, for a lighter machine, linear bearings running on steel rod. Possibly trapezoidal leadscrews with anti-backlash nuts. It's always possible to pay just a bit more and get a better machine - it's getting the cost/benefit balance right that's difficult. However, your requirements are not over-demanding, so that might work OK.
One alternative that might be worth considering is one of the cheap-ish Chinese machines. For example, I've just done a very quick search and come up with this. I have no experience of these machines, but mechanically this would probably fit the bill. This particular machine comes with a water-cooled spindle and variable-speed drive which is far superior to the Kress-type spindles from the point of view of noise/reliability - they will run for hours, which they might need to do with a lighter-weight machine taking lighter cuts. The big problem with these cheap imported machine is that the electronics is really poor, but you are looking at a price for a ready-built machine with spindle, including ballscrew drive, for around the same cost as a C-Beam kit (from a quick look at their web site). You might need to upgrade/replace the electronics but will have a larger capacity, more capable machine for not much higher cost.
I can't spend your money for you, but my personal preference would be to build, take my time, and look for good-quality components matched to my needs. But if you regard them as a part-finished kit of parts, the cheaper Chinese machines might be worth a look if you buy with your eyes open. At the very least, I hope that I have pointed out some alternatives worth researching.
By the way, it's a bit unkind to pick up a typo, perhaps, but this one is unfortunate to put it mildly. In the C-Beam machine write-up on the Ooznest web site, it says that " His video goes meretriciously through every step of the build". Pity this wasn't proof-read more carefully - "meretricious" according to the Oxford Dictionary of English means "Apparently attractive but having no real value". I'm sure that they meant "meticulously"...Last edited by Neale; 24-02-2018 at 08:32 AM.
24-02-2018 #7
You mention engraving on thin brass and aluminium. This obviously isn't about hogging metal but my experience a long time ago with a Marchant Dice machine was that backlash, rigidity and frame strength will be your enemies here, particularly with the usual conical engraving bits - good engraving takes no prisoners and if the tool height above workpiece changes (in my old case - deflection on the unsupported X-rails) then the radius of the engraver cutter changes; backlash and rigidity will give you odd shapes when the tool path changes. Don't underestimate the challenges of engraving. My use-case was PCB routing - cutting through 35 microns of copper at a fixed depth is challenging (if the height varies, then so does the track widths, and artefacts around track corners can decimate the track).
has anyone got and experience with this set up or something similar
By tombomb in forum Machine DiscussionReplies: 0Last Post: 11-05-2015, 03:27 PM -
My CNC build experience so far
By Bez in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 17-02-2015, 11:08 PM -
Anyone had experience with one of these Coolubricators...
By Wal in forum Swarf & Chip ManagementReplies: 4Last Post: 06-04-2014, 02:16 PM -
By Wal in forum Marketplace DiscussionReplies: 0Last Post: 06-02-2014, 01:07 AM -
EXPERIENCE: XYZ Machine - My Experience
By David Maybury in forum Trading Experience & FeedbackReplies: 0Last Post: 03-12-2012, 11:04 AM
