Thread: 1220 × 2440 build
03-03-2018 #41
What would you recommend instead Dean? I keep thinking about the logistics of it, I don't have a forklift at home haha
http://www.ukcnc.info/forums/showthr...-November-2014
I was impressed by this one but haven't (can't) work out how much it'd cost.
Sent from my SM-G935F using Tapatalk
03-03-2018 #42The Bottom Pic looks very much like Merchant Dice machine and just ask anyone about how well MD machine performs....Clive
03-03-2018 #43
04-03-2018 #44
Well all can say is build it stronger or should say Stiffer. If your limited with logistics then build it sections so can be easily moved. It will add another level of complexity because still need to maintain accuracy which is harder to do with more pieces.
Going to say this again because cannot stress enough. Your Gantry design is WEAK and if you build this it will show in the quality of finish.
The Gantry and Z axis are key areas. Malcolm as already mentioned to his pain that Z axis is key area and soon shows any weakness in the cut.
I don't agree that is Gantry is over built and changing to lighter Section profile wouldn't give any better performance really and could potentially cause other issues with resonance when cutting deep or hard materials.
Better having strong gantry that is little heavier than light gantry that will flex when cutting hard. If higher feeds are required then better to size the screws or motors to suit rather than under build.
Under building because of Logistics or weight is just going to compromise the machine performance. Better to think smarter and design around any restrictions.
04-03-2018 #45
I recon my gantry weighs at least 100kg, surely reducing that alittle with a lighter profile aluminium wouldn't hurt??
04-03-2018 #46
Ok I guess your main profile is 160x40 and top/bottom profile 80x40.? The weight difference between HD and light for 160x40 is 3Kg per meter and 2.5kg perM on 80x40.
So lets say gantry is 1500mm wide so in total your only saving approx 12kg and this won't make a huge difference in performance. The extra strength it provides will be more beneficial when cuttng hard than the any slight speed it may gain.
04-03-2018 #47
04-03-2018 #48
When all is short , it looks very sturdy. In 3m length even the 100x100 box section feels like makaroni. If steel, i would say gantry will have to be minimum 100x200x3 beam at the very least. So for aluminum i dont know what Dean uses, but i think 2x 90x180 in L configuration will do the job.
If you want as cheap as possible you have to do all from steel. There is no escaping that. The bigger the steel you use, the simpler the structure will be. 100x100 will need no diagonal bracing, if done right. If you get your hands to 100x200x4 or thicker, that will simplify greatly the whole build. 100x100 is the maximum a Rage saw can cut, hence the maximum you could cut at home.Last edited by Boyan Silyavski; 04-03-2018 at 09:11 AM.
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
04-03-2018 #49
04-03-2018 #50
Here's design that will allow you to be more flexible with the frame. Although the base here is in one piece it could easily be made in 2 or 3 pieces and bolted together.
The important part is the full-length profile section running full length down each side. This will allow you some flexibility in adjustment so can get both rails on same plane without messing around epoxy resin etc. Must stress thou the accuracy will only really be good enough for cutting woods and softer materials. It will also take lot of setting up and tweaking until spot on.
In my experience profile is relatively flat and straight enough for wood router and does make fitting rails, ball screws etc much easier. The downside is cost so mixing steel and profile gives good balance of strength, costs and accuracy with ease of building which doesn't require too much machineing or timely and costly techniques for leveling etc.
The Following 4 Users Say Thank You to JAZZCNC For This Useful Post:
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: New Build Log ... 2440 X 1220 X 300
By Wobblybootie in forum DIY Router Build LogsReplies: 30Last Post: 17-10-2014, 11:20 AM -
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Router 610 x 1220 x 200
By Stickio in forum DIY Router Build LogsReplies: 12Last Post: 18-08-2011, 07:27 PM
