Page 1 of 3 123 LastLast
    Hello all
    While I wait for the new CNC machine been made by JazzCNC I'm watching tons of various cnc vids on youtube every night with excitement :)
    Last night I came across diamond drag compression bit mounted in the spindle, (spindle turned off) then just drag around to etch glass or stone etc..
    My question is.. Is this bad for the spindle and mount assembly as your basically pulling it about with a force against it?
    If not.. cool as it looks quite fun.
    Quote Originally Posted by jmac80 View Post
    Dodgy Geezer him watch it.!
    No won't affect spindle provided not constantly using it this way. In which case you would have it mounted to Z axis in it's own holder.
    Off course.. mount it to the z axis.. makes sense and now you say it.. so obvious :)
  5. #4
    I’ve just recently started using one of these engraving carbon is so much easier quicker and cheaper.
    I only put a Z depth of .75 meaningless I no because it depends on spring tension.
  6. #5
    What one do you use mate?
    I see this USA one with 1/2 or 1/4 shank for about $180.. then a UK based one for about £45..
    Is the usa one just a fancy "Made In the USofA" sticker adding
    £100? :)
    $180
    http://www.widgetworksunlimited.com/..._engrv-500.htm
    or
    £45
    http://www.dragengraving.com/
  7. #6
    I actually got mine from the good old US of A but was £56 if I recall from this seller, I’ve got a new diamond saved just in case.
    https://rover.ebay.com/rover/0/0/0?m...2F292371269198
    But that’s pants down price for what I’m doing it does the job just fine, I’m only engraving logos and my RC name on parts.
    I used to use a normally engraving bit but carbons tolerances of +-5% means engraving was a ball ache, I only engraved .1 deep so some parts would get missed that’s when the ball ache came in I’d need to re do those missing bits
    Engraving carbons only braking the resin so not a great deal of load.
    Shows up real nice when you add some colour
  8. The Following User Says Thank You to Dean jeffery For This Useful Post:
  9. #7
    Oh man that look's sweeet
    What do you use to add colours, just spray paint then wipe off glossy surface instantly with maybe a bit of masking..?
  10. #8
    Dean makes some nice parts I've seen them in the flesh.
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  12. #9
    I just used a sharpie pen colour then wipe off then keep doing it till it’s nice and clear, then used a Q tip dipped in petrol to get any off that dried before I wiped off
  13. #10
    simple but effective :)
    Only thing with sharpies is life span, wife uses them on jewellery she hand stamps.
    bit of masking and airbrush maybe the thing to try.
    Have you ever tried laser engraving with your cnc router? also looking at them 4w laser addons and they look quite fun s well :)
  1. Drag Knife anyone?
    By JoeHarris in forum Tool & Tooling Technology
    Last Post: 07-11-2019, 08:32 PM
  2. diamond impregnated brazing rods uk
    By Fivetide in forum Welding, Brazing & Equipment
    Last Post: 23-11-2016, 11:14 PM
  3. Is there a specific setting for using a diamond drag tool for engraving?
    By petesos in forum Tool & Tooling Technology
    Last Post: 14-03-2014, 12:22 AM
  4. Drag Chains
    By Mad Professor in forum General Electronics
    Last Post: 30-04-2013, 11:23 PM
  5. Drag chains
    By jcb121 in forum General Discussion
    Last Post: 14-05-2012, 11:44 AM
