Thread: Best Drive for Fanuc AC servos
01-02-2018 #1
Ive just bought a Boxford 250F that is running 3ph Fanuc OT system. I had planned to runn it off a converter but I understand that the OT system is quite old and cant handle large programmes.
I could reto fit with steppers but it seems crazy to loss the fanuc servos for steppers.
If I convert to 240v single phase I would like to retain the motors and run from linux cnc with mesa cards.
Ive seen The pico system and granite devices do a compatable drives but the pico is standalone and the GD is pricey.
Are there any other drives available or anyone done a similar project?
02-02-2018 #2
If the existing servo drives work (technically they're Servo Amplifiers, and a search should turn up more options) , keep them. You'll just need to figure out what they are, and what signals they need to run (they'll be +/-10V analogue drives, but you'll need to find enable/fault signals).
Other option is you convert to something like the CNC Drive DC servo drives, which will accept a step/dir signal, removing the need for an analogue controller.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
02-02-2018 #3
Unfortunally the lathe is at a freinds workshop at the moment so I cant check model numbers ect. I just assumed that the Fanuc drives cant be used as I couldnt find any examlples of people doing it. Also they are 3 phase so I would still need a rotary converter.
in the documents it looks like the spindle VFD has already been changed for a Mitubishi 240v one, if so that takes care of the spindle so its only the servo drives that need to be changed to get it all on 240v.
Can I use DC servo drives on an AC motor?
02-02-2018 #4
Are you sure they're AC servos?
From what I'm aware, most machines of that era used DC servos. The 3 phase will go through a transformer, before being rectified to provide DC for the amps.
You really need to get model numbers of everything.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
02-02-2018 #5
02-02-2018 #6
Oh.
Selling them and buying some new servos and drives is likely to be the far easier option, if you do want to change the control.
Lack of program memory on a lathe isn't that big a problem, as most lathe programmes aren't that big anyway.
But it all depends on where you want to spend time and money, between running the existing system, or fitting a new system.
I'd be seeing how much a working Fanuc system is worth, and making a decision from there.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
02-02-2018 #7
The mesa stuff is known to drive motors/servos well.
Granite D. is actually cheap ..
Getting any of the commercial/fanuc servos running well has been an adventure, in general, for others.
It will be very cheap to try with a granite d. system, vs anything else ..
and about 3x easier, imho.
There are endless caveats, most are unlikely.
So it might be it wont work .. but this is 5-10% probability.
Using the granite d. stuff makes you 10x more likely to succeed - imho.
Ross here is the link to the drives https://granitedevices.com/products/
and a page that might be able to walk you through http://www.wiki.eusurplus.com/index.php?title=Main_Page
as you know I am following this..Clive
02-02-2018 #9
So a big plus for Granite devices then
Not sure I class £420 a drive as cheap though, Would the IONI series be powerfully enough? Modular so I could build up the system as I need it.
Thanks Clive, hadnt found that wiki but looks promising, I could even use my current mesa cards as the GD's accept step direction signals as well as 0-10v
03-02-2018 #10
Had a look today and the motors are Type 3-OS, A06B 0533-B001#7000 and dated 90 04 so guesing April 1990
6 pole, 112v, 0.5Nm and 1 amp, google seems to indicate a 2000ppr incremental encoder.
Are they worth saving or just replace with a all new drives.
Fanuc OT - Fuses blowing
By Cube3 in forum Machine Control SoftwareReplies: 7Last Post: 19-07-2017, 08:03 PM -
Fanuc w3 paramaters
By Ismirko in forum Machine DiscussionReplies: 3Last Post: 03-02-2015, 08:29 PM -
NEW MEMBER: Fanuc Macro programming
By curly3456 in forum New Member IntroductionsReplies: 0Last Post: 02-02-2012, 10:20 PM -
Fanuc, any one know this well, need pointers/help
By fastcarl in forum Machine Control SoftwareReplies: 2Last Post: 26-08-2011, 07:46 AM -
Leadwell/ Fanuc Om control manual
By fastcarl in forum Machine DiscussionReplies: 0Last Post: 26-06-2011, 11:09 AM
